Def system delete kit?
Thinking of performing the delete kit for my new 2012 f350 diesel. I'm not sure yet if it's worth risking the loss of my warranty. Any thoughts or ideas? Is anyone using one on theirs and if so which ones are recommended? Thanks! :-drink
I am just curious. Admittedly i am pretty much in the "stock" crowd when it comes to engine/exhaust.
Having said that why would you want to trade off warranty for the delete? Are the benefits worth the risk in your mind? Not a shot, jsut want to know what you are thinking. |
I'm told that I will gain hp, fuel economy and not have to deal with constantly adding the fluid.
Originally Posted by Eliteac
(Post 11247697)
(Post 11247697)
Adding DEF is not that big of a deal, not any harder than adding window washing fluid. |
I'm told that I will gain hp, fuel economy and not have to deal with constantly adding the fluid. Lots of hp already....won't get much, if any better fuel economy, and you hardly ever have to add fluid. I don't even think about that anymore. I'd keep the warranty if I were you. -- Gordon |
I suspect that you would gain a lot more mileage, were you to delete the DPF.
It actually uses fuel for the burnoff. |
Originally Posted by Mcmurphrjk
(Post 11248122)
It actually uses fuel for the burnoff. DEF and DPF are two different things so is the regen process if that's what you mean or are trying to say. Big deal dumping in DEF fluid every oil change or so. If thats such a hard task, go back to a gas truck. |
Originally Posted by Grassman09
(Post 11248629)
What are you saying here?
DEF and DPF are two different things so is the regen process if that's what you mean or are trying to say. Big deal dumping in DEF fluid every oil change or so. If thats such a hard task, go back to a gas truck. If I was determined to delete the DEF, (which I'm not), I would delete both the DEF and the DPF. |
It's not that its difficult to add the fluid. It's that I have about 2000 miles on it and I already have a problem with it. I've been doing a lot of reading on here and see that a lot people are havingbthensame problem. After I filled it I received and error saying that the system has malfunctioned and speed will be limited. After asking around locally most are saying rip that piece of crap out of the exhaust for less restriction and use the h&s programmer to delete it. Supposedly I'd get around another 5 mpg. Not sure though. Thats what led me here. :-missingt
I wouldn't change the truck till about 80k miles. You have to let the warrenty fix these minor problems.
From what I've heard, a new crate motor is around $18K! Of course, that doesn't include the labor charges to remove and install the old and new. I think I'll just keep my warranty intact and deal with the DEF and DPF
Why don't you simply have them repair the DEF problem. All it does it make the air cleaner for you and me to breath.
Now dont get me wrong if your a mod buff and want more hp then maybe do a comlete DPF and EGR and DEF is for you. |
Search: Powerstrokehelp on YouTube. He does a decent job explaining the def and scr system and why the 6.7L motor doesn't need tuners and deletes. I would wait a bit for the aftermarket to catch up to this motor and save your warranty for a while.
(Post 11248981)
Rob |
