Def system delete kit? - Ford Truck Enthusiasts Forums
Old 01-06-2012, 09:10 PM
Eliteac Eliteac is offline
Eliteac is starting off with a positive reputation.
Question Def system delete kit?
Thinking of performing the delete kit for my new 2012 f350 diesel. I'm not sure yet if it's worth risking the loss of my warranty. Any thoughts or ideas? Is anyone using one on theirs and if so which ones are recommended? Thanks!
Old 01-06-2012, 09:23 PM
jack_pine's Avatar
jack_pine jack_pine is offline
jack_pine is starting off with a positive reputation.
I am just curious. Admittedly i am pretty much in the "stock" crowd when it comes to engine/exhaust.
Having said that why would you want to trade off warranty for the delete? Are the benefits worth the risk in your mind? Not a shot, jsut want to know what you are thinking.
Old 01-06-2012, 09:36 PM
I'm told that I will gain hp, fuel economy and not have to deal with constantly adding the fluid.
Old 01-06-2012, 10:30 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
Quote:
Yes, Yes, and Yes. Don't forget about added sound and black smoke!
Old 01-06-2012, 10:42 PM
6.7L 6.7L is offline
6.7L is starting off with a positive reputation.
I'm sure it will have some impact to your warranty but not sure if there will be any noticeable increase in HP with a DEF delete, may be if you also change the pipes with less restriction in back pressure. IMO, this is a NOT a good HP mod for the money.
Adding DEF is not that big of a deal, not any harder than adding window washing fluid.
Old 01-06-2012, 10:49 PM
fixdent fixdent is offline
fixdent is gaining momentum as a positive member of FTE.
Lots of hp already....won't get much, if any better fuel economy, and you hardly ever have to add fluid. I don't even think about that anymore. I'd keep the warranty if I were you.
Gordon
Old 01-06-2012, 11:00 PM
Mcmurphrjk Mcmurphrjk is offline
Mcmurphrjk is starting off with a positive reputation.
I suspect that you would gain a lot more mileage, were you to delete the DPF.
It actually uses fuel for the burnoff.
Old 01-07-2012, 01:35 AM
Grassman09's Avatar
Grassman09 Grassman09 is offline
Grassman09 is starting off with a positive reputation.
What are you saying here?
DEF and DPF are two different things so is the regen process if that's what you mean or are trying to say.
Big deal dumping in DEF fluid every oil change or so. If thats such a hard task, go back to a gas truck.
Old 01-07-2012, 02:35 AM
That was my point, it would likely be a greater benefit to delete the DPF and stop using fuel for regen, than mess with the DEF system for what would likely be minimal gain.
If I was determined to delete the DEF, (which I'm not), I would delete both the DEF and the DPF.
Old 01-07-2012, 08:22 AM
It's not that its difficult to add the fluid. It's that I have about 2000 miles on it and I already have a problem with it. I've been doing a lot of reading on here and see that a lot people are havingbthensame problem. After I filled it I received and error saying that the system has malfunctioned and speed will be limited. After asking around locally most are saying rip that piece of crap out of the exhaust for less restriction and use the h&s programmer to delete it. Supposedly I'd get around another 5 mpg. Not sure though. Thats what led me here.
Old 01-07-2012, 08:33 AM
farmerdave farmerdave is offline
farmerdave is gaining momentum as a positive member of FTE.farmerdave is gaining momentum as a positive member of FTE.
I wouldn't change the truck till about 80k miles. You have to let the warrenty fix these minor problems.
Old 01-07-2012, 08:54 AM
xrated xrated is offline
xrated is starting off with a positive reputation.
From what I've heard, a new crate motor is around $18K! Of course, that doesn't include the labor charges to remove and install the old and new. I think I'll just keep my warranty intact and deal with the DEF and DPF
Old 01-07-2012, 10:10 AM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Why don't you simply have them repair the DEF problem. All it does it make the air cleaner for you and me to breath.
Now dont get me wrong if your a mod buff and want more hp then maybe do a comlete DPF and EGR and DEF is for you.
Old 01-07-2012, 10:25 AM
Search: Powerstrokehelp on YouTube. He does a decent job explaining the def and scr system and why the 6.7L motor doesn't need tuners and deletes. I would wait a bit for the aftermarket to catch up to this motor and save your warranty for a while.
Old 01-07-2012, 12:11 PM
rob17's Avatar
rob17 rob17 is offline
rob17 is starting off with a positive reputation.
That surprises me. I've on this forum since I bought my 6.7 and although there have been some with problems I've been pleasantly surprised by how few problems have been reported.
Rob
delete or bullet proof the EGR? USCG_PA Excursion - King of SUVs 14 03-02-2014 02:58 PM
EGR Delete Regulator1988 6.0L Power Stroke Diesel 16 05-28-2012 05:36 PM
THE BEST EGR DELETE KIT bigkountry926 6.0L Power Stroke Diesel 16 06-18-2010 02:43 AM
Does anyone have anything bad to say about the Liberator EGR Delete Kit? berick 6.0L Power Stroke Diesel 21 06-29-2009 12:29 AM
What is an EGR delete? bkvanbek 6.0L Power Stroke Diesel 28 01-10-2009 01:27 AM
Tags
2011f350, 2012, 67, def, delete, deleting, diesel, dpf, f250, f350, ford, gain, hp, kit, kits, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
