92 f150 Key on engine running test
I just did a koer test on my 92 f150 302 i got the codes from it but am not sure if they are supposed to be 2 digit codes or 3 digit codes the numbers that came up are 1124135212411352
I'm thinking the '92 should be 2 digit codes..
that was what i was thinking also but the first code is 11 which is system pass but then it gives me 6 more codes. Unless maybe I read it wrong.
My chiltons shows there are two and three digit codes.I think you should do the KOER test again and notice where the pauses are.They separate the different codes as they come up.
'92 was one of the inbetween years for the 2 or 3 digit code transition, but I'm thinking the 302 was still 2-digit in '92.
Keep in mind that in a KOER test, there will be an engine code first (4 flashes for an 8-cylinder engine), then a "goose code" to prompt you to give the throttle a quick stab, turn the steering wheel 1/4-1/2 a turn, touch the brake pedal and cycle the O/D switch (last two are for electronic automatic trucks only). After that, there will be a short flicker which are the fast codes used by some code readers, then it gets to the actual codes. The computer will output all codes then output them all a second time. |
