Factory 6.2 Internals.
What are they? Forged? Cast Iron?
A little bit of everything..
The 6.2 engineer answered a bunch of questions in this thread: https://www.ford-trucks.com/forums/9...as-engine.html Details of the motor: 2011 FORD SUPER DUTY BOASTS 6.2-LITER GAS ENGINE .: News Key features of the new 6.2-liter V-8 gasoline engine include: *Cast-iron engine block and four-bolt main bearing caps, with cross bolts, for durability *Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder *Cast-iron crankshaft, with dual-mode damper *Forged steel connecting rods *Cast-aluminum pistons, with cooling jets *Single overhead camshaft with variable valve timing and roller-rocker shaft valvetrain *Magnesium cam covers for lighter weight *Stamped-steel oil pan *Composite intake manifold *Stainless-steel fuel rail; port-fuel-injected; mechanical returnless fuel system *9.8:1 compression ratio *E85/flex fuel capable |
