You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Key features of the new 6.2-liter V-8 gasoline engine include:
*Cast-iron engine block and four-bolt main bearing caps, with cross bolts, for durability
*Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder
*Cast-iron crankshaft, with dual-mode damper
*Forged steel connecting rods
*Cast-aluminum pistons, with cooling jets
*Single overhead camshaft with variable valve timing and roller-rocker shaft valvetrain
*Magnesium cam covers for lighter weight
*Stamped-steel oil pan
*Composite intake manifold
*Stainless-steel fuel rail; port-fuel-injected; mechanical returnless fuel system
*9.8:1 compression ratio
*E85/flex fuel capable
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
