curbill4 |
11-15-2011 02:36 PM |
What should timing be set to run WVO
On a 1993 7.3 non-turbo Auto is there any special setting that my injector pump be set for? I have a little over 100,000 miles running wvo on 4 mercedes 5 cyl diesels. I centrifuge my oil and dewater it. It goes thru a 1 micron sock and I now see less fat in my filters. I have 2 tanks in this ford and heat on both. I presently run a 50/50 blend in the ford. My IP just crapped out and a rebuilt was installed. I have a mechanic who is set-up to time the engine with a pheret timing adapter. I just wonder if I should have a different setting than what ford calls for. The engine has less than 10,000 miles since a complete rebuild. The prior owner did not believe in oil changes. I am in So Fl and we do not get temps below 40 degrees. If it gets that cold I just wait till the sun comes up to start the benz's. Thank you.
