Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-15-2011, 02:36 PM
curbill4 curbill4 is offline
Garage is empty, add now
curbill4 is starting off with a positive reputation.
What should timing be set to run WVO
On a 1993 7.3 non-turbo Auto is there any special setting that my injector pump be set for? I have a little over 100,000 miles running wvo on 4 mercedes 5 cyl diesels. I centrifuge my oil and dewater it. It goes thru a 1 micron sock and I now see less fat in my filters. I have 2 tanks in this ford and heat on both. I presently run a 50/50 blend in the ford. My IP just crapped out and a rebuilt was installed. I have a mechanic who is set-up to time the engine with a pheret timing adapter. I just wonder if I should have a different setting than what ford calls for. The engine has less than 10,000 miles since a complete rebuild. The prior owner did not believe in oil changes. I am in So Fl and we do not get temps below 40 degrees. If it gets that cold I just wait till the sun comes up to start the benz's. Thank you.
  #2 (permalink)
Old 11-17-2011, 12:45 PM
eatont9999's Avatar
eatont9999 eatont9999 is offline
1991 Ford F-250
eatont9999 is starting off with a positive reputation.
With all the reading I have done, people seem to suggest advancing the timing a small amount for adding a turbo or running thicker fuel/WMO/WVO. I'm no expert and I haven't had the time to do proper testing but I plan on 10-11 degrees BTDC when I install my turbo and start running WMO. The logic behind the advancement is the increased cylinder pressure with a turbo can retard the injection of fuel. I would guess something similar is happening when running fuel other than #2.
__________________
1991 F250 7.3 IDI, Supercab, 2WD, 10.25 Sterling with 3.55s, E4OD, Hydroboost, rebuilt Banks Sidewinder.
1983 300SD - Needs lots of love. UMO test vehicle.
"I gave y'all a couple 'a good ol' revs of the straight pipe, so if y'all got any b!+ch'n 'er complainin', go ahead and keep it to yourself." -- Me
Tags
69, 73, adapter, diesel, ford, idi, mercedes, run, running, set, small, timing, wmo, work, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
