Originally Posted by Mspette
(Post 10913911)
I uninstalled the manual switch and put it back as stock.
Did you look at the powertrain diagram I posted earlier? Those items are on the same keyed power feed so maybe we just need to find out if there is a broken wire somewhere. Have you tested the relay with a meter to see if it's working? |
I have 12 v-dc at the always live lug then I turn the egnition on and the other big terminal becomes energised
(Post 10913949)
the manual switch that i put in replaced the original 2 little wires that come from the wireing harnis I taped the ends of each wire and left them to the side and put te manual switch in. Now however I removed the manual switch and re connected the original wires that come from the wireing harnes
I just double checked the New Relay I installed. As I said earlier I returned It to stock and with out the manual relay switch and now the 12V-DC does not transfer to the 2ND big terminal like it is seposto
(Post 10914043)
Do you still have your old relay? If so, then you might consider removing the relay from ebay and setting it aside for now. Take your AIH relay and put it where your GP relay was. Then put your old relay (the one that you recently removed) in the AIH spot. Wire everything back up like the photo I posted and see if your truck starts. |
when wireing the manual switch you put the two bigger wires on the same terminals as the old relay. you put the two other wires to the side. then you put a jumper wire on the relay from theone big terminal that is always hot to one of the little terminals. then you put a wire from the outher little terminal on the relay to a momentary toggle switch and then you go from the other side of the momentary toggle switch to ground.
(Post 10914195)
...you put the two other wires to the side. t...
How did you protect the wires while they were set aside? One of those would have full time power when the key is on... |
taped them off
Originally Posted by ToMang07
(Post 10913888)
I would double-check the fuses again, too.
Have you checked your fuel pump inertia switch? It's located behind the front passenger side kick panel. |
yes is ok not tripped
it is not tripped but i reed no power on either one of the 2 wires that go to it
I just we to Auto Zone and bought a new relay. I installed it in the conventional manner and no change. I hane power 12V-DC at the power terminal, Turn the ignition on and no power at the oposimg big terminal.
(Post 10914824)
What year is your truck? Do you have the second fuse panel under the hood? Try swapping the PCM relay with the blower relay and see if that helps. Sounds like the fuse to the PCM relay coil is popped. |
Subscribing...
