Engine Cranks but wont start - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-12-2011, 01:25 PM
Mspette Mspette is offline
Mspette is starting off with a positive reputation.
Hi all, I have a 2002 F350 duly I drove home the other night, parked in the driveway and went in and had dinner. About an houre and a half later I opened the hood and repaaced the G P R wire for wire to terminal for terminal. went to start the truck and she cranks but will not start. I connected a O B D 2 scanner to the diognostic port and in says it can not connect so I don't have the benifit of any DTC'. any help or ideas would be greatly appreciated.
Thank You,
Mark
<!-- / message -->
Old 10-12-2011, 01:27 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Does your Wait To Start light come on?
Which wire did you replace?
Old 10-12-2011, 01:46 PM
Greg thank You for taking your time to reply, I replaced the glow plug relay and re conected the wires on the new relay as they were on the old relay Thankyou ,
Mark
Old 10-12-2011, 01:49 PM
Quote:
Mark
OK. So I presume your wires look like the photo I posted....
Does the Wait To Start light come on?
Old 10-12-2011, 01:54 PM
JamesHajek's Avatar
JamesHajek JamesHajek is offline
JamesHajek is gaining momentum as a positive member of FTE.JamesHajek is gaining momentum as a positive member of FTE.
What GPR did you replace it with?
If that was all you did and you replaced it with the right GPR, it should start...
The wiring on the GPR doesn't matter as long as you get the big wires on the big lugs and the little wires on the little lugs...
Old 10-12-2011, 01:59 PM
the glow plug lite does come on and i bought the relay on e bay there is a guy that sell a lifetime relay. In addition to that you can buy a manual switch so you only use the relay/glow plugs when it is cold out.
Mark
Old 10-12-2011, 02:00 PM
correctiom IS NOT cold out
Mark
Old 10-12-2011, 02:02 PM
switch on manuely when the temp is cold NOT having to use in warmer wether
Mark
Old 10-12-2011, 02:12 PM
Mark
So, did you wire in the manual switch? If so, remove it, check your fuses and replace if blown and then see if the truck starts.
Do you hear your fuel pump when you first turn the key on?
Is there any smoke out the tailpipe while cranking?
Old 10-12-2011, 02:20 PM
I checked every fuse with a multi meter. No sound that I can here of fule pump. No smoke from tail pipe. I do here a relay clicking when i turn the ignition switch to the on position. It is relay# 303 (Injection Drive Module Relay) i changed relay and it still clicks untill you turn the key to the off position
Thanks, Mark
Old 10-12-2011, 03:00 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
No smoke while cranking means the injectors are not firing. Make sure you have 10.5 volts WHILE cranking.
The IDM will not fire the injectors with much less than 10.5 volts while cranking.
Edit: Here's some info
Old 10-12-2011, 03:30 PM
Payson thankyou for replying, The batteries are up tp snuff and the engine cranks fast. However the I D M Relay clicks as if it wern't getting enough power to pull it in. I took a 2 gage jumper cable from the battery to the power lug of the fusebox just to make sure I had proper voltage to the fuse block. Thanks Mark
Old 10-12-2011, 03:38 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
I know you checked all of the fuses but check #30 again I think.It is the one that says cigar lighter.It is tied to the fuel bowl heater and pcm.If it is blown because the fuel bowl heater shorted out it will not start.
Old 10-12-2011, 03:42 PM
Thanks, Mark
Clicking relays is usually low voltage. The engine will turn over pretty fast even when the batteries are down. You must check voltage with a meter while cranking to be sure.
Like Robin said, no smoke means the injectors are not firing (or there isn't any fuel available). There was a thread a while back where someone had no voltage at the fuel pump. They found a defective wire at the glow plug relay, fixed it and their fuel pump started working. I still don't know how that had any play but according to the attached wiring diagram, the keyed power for the glow plug solenoid is on the same circuit as the fuel pump so that could be your issue. Depending on how you wired up your manual switch, you could have affected the fuel pump somehow. Again, I am not sure how that can happen but I just remember that thread and how the OP solved his issue.
Here is the diagram.
File Type: pdf 2002-Powerstroke_Powertrain_Control_System_1.pdf (800.2 KB, 77 views)
Old 10-12-2011, 03:44 PM
ok will go and check cranking voltage and fuses
Rewire/Duraspark II question Tparkin99 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 11-13-2016 07:54 AM
Alternator/External Voltage Regulator 72fordf100 Bigpain2000 1967 - 1972 F-100 & Larger F-Series Trucks 26 08-31-2015 02:16 PM
Slow crank rangergirl94 1987 - 1996 F150 & Larger F-Series Trucks 18 01-10-2012 09:10 PM
2002 PSD, rodent damage, need wire connector help rgconway 1999 - 2003 7.3L Power Stroke Diesel 8 11-11-2009 11:02 PM
Tags
1999, 2003, 46, 68, crank, cranks, engine, expedition, explorer, f250, f350, ford, liter, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
