Cummins Swap
I was looking at swaping in a 5.9l cummins into a 74' F250 High boy and i was wondering if any one of yall had done this at all and had a list of parts needed for the swap I plan on buying a junked truck to pull the engine and wiring and ect... I planned on mating it to a E4OD tranny with the adapter plate on the engine to be able to use a standard bell housing.
Any input would be greatly appriecated. And before I get any brand name haters Ford does use cummins the the larger trucks as an option. |
Use the search function, there is plenty of info in the forums.
Good swap. No one I've heard of hates on Cummins. I kinda wish some DID, so I could score one cheap to try in one of my spare Fords. |
https://www.ford-trucks.com/forums/7...-crew-cab.html
Have a read here. |
Thanks that helps a bit.
There are several cummins swaps going on in the engine swaps section here Engine Swaps - Ford Truck Enthusiasts Forums
I have a 93' industrial 5.9 bought direct from cummins. Finding a complete donor vehicle is an easier solution. |
Thanks for the info I will hop on over and read a bit.Yea I was thinking about that especially since I want a newer like 03 to 05 common rail so I am going to need some wiring.
The E40D is going to need some major upgrades to handle that. Destroked has most of the specialty parts you need.
Yeah I know it should be fun though to get to the power levels I want it is definitely gonna have to be forged parts not billet ya know other wise I am gonna snap input shafts left and right explode gears and rip bell housings. :p
A stock E4OD will handle a stock Cummins without a problem.
It can be upgraded to handle 1,000 ft pounds. Lots of info on these sites: http://www.4btswaps.com/ Dodge Cummins Diesel Forum Destroked or Ford Cummins will have the parts you need. |
