Cummins Swap - Ford Truck Enthusiasts Forums
Cummins Swap
Old 08-25-2011, 07:22 AM
USArmyTaterness's Avatar
USArmyTaterness USArmyTaterness is offline
USArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant future
Cummins Swap
I was looking at swaping in a 5.9l cummins into a 74' F250 High boy and i was wondering if any one of yall had done this at all and had a list of parts needed for the swap I plan on buying a junked truck to pull the engine and wiring and ect... I planned on mating it to a E4OD tranny with the adapter plate on the engine to be able to use a standard bell housing.
Any input would be greatly appriecated.
And before I get any brand name haters Ford does use cummins the the larger trucks as an option.
Old 08-25-2011, 09:22 AM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
Use the search function, there is plenty of info in the forums.
Good swap. No one I've heard of hates on Cummins. I kinda wish some DID, so I could score one cheap to try in one of my spare Fords.
Old 08-25-2011, 09:25 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Old 08-25-2011, 11:02 AM
Thanks that helps a bit.
Old 08-26-2011, 05:08 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
There are several cummins swaps going on in the engine swaps section here Engine Swaps - Ford Truck Enthusiasts Forums
I have a 93' industrial 5.9 bought direct from cummins. Finding a complete donor vehicle is an easier solution.
Old 08-27-2011, 05:51 AM
Thanks for the info I will hop on over and read a bit.Yea I was thinking about that especially since I want a newer like 03 to 05 common rail so I am going to need some wiring.
Old 08-27-2011, 12:02 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
The E40D is going to need some major upgrades to handle that. Destroked has most of the specialty parts you need.
Old 08-27-2011, 12:07 PM
Yeah I know it should be fun though to get to the power levels I want it is definitely gonna have to be forged parts not billet ya know other wise I am gonna snap input shafts left and right explode gears and rip bell housings.
Old 09-28-2011, 02:54 PM
philofab's Avatar
philofab philofab is offline
philofab is starting off with a positive reputation.
A stock E4OD will handle a stock Cummins without a problem.
It can be upgraded to handle 1,000 ft pounds.
Lots of info on these sites:
http://www.4btswaps.com/
Dodge Cummins Diesel Forum
Destroked or Ford Cummins will have the parts you need.
56 f600 cummins conversion rustyrelic Large Truck 64 08-18-2016 10:56 PM
Super Duty Cummins Swap jerem0621 1999 to 2016 Super Duty 9 12-31-2012 07:10 PM
Cummins superduty gas pedal SteveNCf250 Engine Swaps 5 04-16-2012 06:28 PM
Ford CC Cummins swap msbweiland 1973 - 1979 F-100 & Larger F-Series Trucks 72 10-26-2007 01:01 PM
Ford Cummins? whooboy General Diesel Discussion 13 01-24-2006 11:26 AM
Tags
bronco, cummiins, cummins, dentside, engine, f250, ford, industrial, motor, parts, swap, swaping, swaps, swop, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
