How to replace a serpentine belt
My buddy has a 2001 7.3 and we are planning to replace the serpentine belt. He has the dual alternator. Anyone have a step by step. I just finished mine on 6.0. Need the routing and any tips that anyone has gained.
1 Attachment(s)
Originally Posted by Headviking
(Post 10502221)
Here is a photo that shows the routing of the belt for dual alts. |
On some models, you must remove the top radiator hose if it goes "thru" the belt..
There should be a label showing the belt routing in the engine compartment.. |
Look for this:
http://i59.photobucket.com/albums/g3...lternator1.jpg Accessory Drive— 7.3L Diesel Engine Single Generator http://i59.photobucket.com/albums/g3...gsinglegen.gif <TABLE border=1 cellSpacing=0 cellPadding=3 width="70%"><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler Pulley (Without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>5 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE> Accessory Drive —7.3L Diesel Engine Dual Generator http://i59.photobucket.com/albums/g3...ingdualgen.gif <TABLE border=1 cellSpacing=0 cellPadding=3 width="70%"><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>4 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE> https://www.ford-trucks.com/forums/5...ml#post5243515 Stewart |
Originally Posted by Stewart_H
(Post 10502365)
Look for this:
I've got the dual alt. and just replaced the belt a couple months back. As stated above just relieve tension on the tensioner and R&R belt. Really easy! Fun fact: I calculated belt length at 11.5'.
Greg.. that's a great image of a 7.3l.. what year model would it be..? It sure not a 99 with that pulley set up..
This is some convenient info, my alt went bad today so I will be changing it hopefully tomorrow. I will probably put my new belt on at same time. Thanks
Greg, I didn't really look at the picture, I just thought the diagrams I posted in the Excursion forum (see the link) would be helpful here too, along with your pic. But now that you mention it, the picture is off a little!
Stewart |
Originally Posted by clintbonnie
(Post 10503259)
I found that photo online and thought it would make a good cover page for my PSD binder. :) |
I just clicked on the image to save it to my hard drive and it saved as 2002stroker.jpg
Stewart,
The small diagram you posted shows the tensioner relief going down, or "clockwise". That doesn't seem right, even for a dual setup. It also shows what appears to be an A/C compressor clutch below the tensioner. That would be for a gasser, not a diesel, wouldn't it? I'd lift up on the breaker bar to relieve belt tension if the actual belt routing looks like the full diagrams given. Pop |
I just did this a few weeks ago. No lock on mine(or I didn't find it) Just follow the sticker under the hood. It's not bad with two people, but is nearly impossible alone. You have to keep moving from top to bottom of the truck and I kept knocking one section off putting the next on. Opening the new belt a few hours ahead of time and let all the kinks work out before hand makes it much easier.
Originally Posted by SpringerPop
(Post 10504217)
Stewart,
The small diagram you posted shows the tensioner relief going down, or "clockwise". That doesn't seem right, even for a dual setup. It also shows what appears to be an A/C compressor clutch below the tensioner. That would be for a gasser, not a diesel, wouldn't it? I'd lift up on the breaker bar to relieve belt tension if the actual belt routing looks like the full diagrams given. Pop Stewart |
Stewart, it's the very first one in Post #4 above, the image named "60Lalternator1.jpg".
Given the file name, it turns out to apparently be for a 6.0, not a gasser, but isn't applicable to a 7.3. Pop |
