Map Sensor
Does anyone know if the Sd sensor is compatible with our trucks?
its 170 for a new sensor from partsguyed. |
uploading that video with the Scangauge reading Manafold pressure with the MAP sensor unplugged as well.
YouTube - ‪June 15, 2011 09:20‬‏
So, my thought is, using scan gauge to figure if map is bad, is not an accurate way to find out. But its just a thought. No idea where its getting its reading from if the sensor is unplugged. |
I might have a good used one. PM me if you are interested.
Might? your not sure yet?
Yea, I'd have to go and look in the shop, and I don't feel like it right now :)
I don't blame ya. its a bit late out.
I'll let you know tommorow. As for the SD compatability, I don't know....
Rodger Dodger.
The scangauge might have the MAP and BAP sensors confused. The barometric pressure sensor is under the dash by the steering column. I guess you know where the map is. If it's reading around 14.7 under a load then it's likely the BAP. My scangauge 2 has the two confused. I had to tweek the programming on it to get them right. Just changed the name of each one on it. With the SG2 they have to be programmed in for a gasser engine also. The diesel x gauge thing doesn't work for those and the engine coolant temp and air temp. Gas engine ones do.
I know it's different gauges we're talking about but it may be the same problem. |
it reads exactly what my isspro boost gauge reads.
The MAP value is probably calculated by the PCM when it sees a bad signal. Just like when you unplug the ICP sensor. The truck will still run even though it doesn't know what ICP is. It just guesses. In your case you truck is a good guesser. Ask it for a lotto number quick.
For the SD MAP not its not interchangeable. |
It doesn't really guess. Map and ICP are a fixed value based on EOT and throttle position I believe. Limp home mode.
Originally Posted by Talyn
(Post 10473118)
The SD MAP sensor is a 0-5V sensor. The OBS sensor output is a variable frequency on a fixed voltage. |
Originally Posted by RRranch
(Post 10474193)
