Map Sensor - Ford Truck Enthusiasts Forums
Map Sensor
Old 06-17-2011, 10:05 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Map Sensor
Does anyone know if the Sd sensor is compatible with our trucks?
its 170 for a new sensor from partsguyed.
Old 06-17-2011, 10:07 PM
Talyn's Avatar
uploading that video with the Scangauge reading Manafold pressure with the MAP sensor unplugged as well.
Old 06-17-2011, 10:10 PM
Talyn's Avatar
YouTube - ‪June 15, 2011 09:20‬‏
So, my thought is, using scan gauge to figure if map is bad, is not an accurate way to find out.
But its just a thought. No idea where its getting its reading from if the sensor is unplugged.
Old 06-17-2011, 10:19 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
I might have a good used one. PM me if you are interested.
Old 06-17-2011, 10:23 PM
Talyn's Avatar
Might? your not sure yet?
Old 06-17-2011, 10:25 PM
plgebbia's Avatar
Yea, I'd have to go and look in the shop, and I don't feel like it right now
Old 06-17-2011, 10:26 PM
Talyn's Avatar
I don't blame ya. its a bit late out.
Old 06-17-2011, 10:30 PM
plgebbia's Avatar
I'll let you know tommorow. As for the SD compatability, I don't know....
Old 06-17-2011, 10:37 PM
Talyn's Avatar
Rodger Dodger.
Old 06-18-2011, 07:34 AM
RRranch RRranch is offline
RRranch is gaining momentum as a positive member of FTE.RRranch is gaining momentum as a positive member of FTE.
The scangauge might have the MAP and BAP sensors confused. The barometric pressure sensor is under the dash by the steering column. I guess you know where the map is. If it's reading around 14.7 under a load then it's likely the BAP. My scangauge 2 has the two confused. I had to tweek the programming on it to get them right. Just changed the name of each one on it. With the SG2 they have to be programmed in for a gasser engine also. The diesel x gauge thing doesn't work for those and the engine coolant temp and air temp. Gas engine ones do.
I know it's different gauges we're talking about but it may be the same problem.
Old 06-18-2011, 07:36 AM
Talyn's Avatar
it reads exactly what my isspro boost gauge reads.
Old 06-18-2011, 07:56 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
The MAP value is probably calculated by the PCM when it sees a bad signal. Just like when you unplug the ICP sensor. The truck will still run even though it doesn't know what ICP is. It just guesses. In your case you truck is a good guesser. Ask it for a lotto number quick.
For the SD MAP not its not interchangeable.
Old 06-18-2011, 09:12 AM
It doesn't really guess. Map and ICP are a fixed value based on EOT and throttle position I believe. Limp home mode.
Old 06-18-2011, 06:13 PM
cleatus12r cleatus12r is online now
cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.
Quote:
Nope.
The SD MAP sensor is a 0-5V sensor. The OBS sensor output is a variable frequency on a fixed voltage.
Old 06-18-2011, 06:32 PM
tjbeggs's Avatar
Quote:
That is what I meant by guess. When the signal is corrupt it goes off a set table rather than actual sensor data
Tourbo pedestal sensor Jsean Jackson 6.0L Power Stroke Diesel 1 01-20-2017 10:31 PM
cleaning EBP sensor ehgeeray 6.0L Power Stroke Diesel 5 03-26-2010 09:12 PM
Baro Sensor location KRDiesel 6.0L Power Stroke Diesel 9 07-25-2009 08:31 PM
MAF sensor fderflinger 1999 to 2016 Super Duty 7 08-21-2007 06:38 AM
Speed Sensor whiteboyslo Ford Inline Six, 200, 250, 4.9L / 300 4 11-06-2001 04:19 PM
Tags
2002, 73, 73l, diesel, ford, gm, idm, map, obs, reading, sensor, shift, trucks, v8, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
