How to jack truck?
Hi all
I am going to do the front brakes and would like to know what the best way to lift the front is and put on stands. I’m not sure what part of the front is best to use to lift. I have a 3 ton floor jack and a 10 ton bottle jack. How about the rear also? Thanks <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p> 2004, F-350 diesel, 4X4, Crew, LB, Auto, 101,000 miles: Bilstein shocks, Fumoto, Zoodad, MBRP 4” turbo back, Edge Insight, EGT probe |
the front passenger side of my 4x4 i jack it up and place a 3ton stand under the leaf spring mount and i just keep the jeck under the drivers front pumpkin but i place another 3ton stand under the drivers side just in case.
The rear i put a piece of wood i cut out to fit in my jack mount and lift the rear up by the pumpkin in the middle place two 3ton stands under the axle right below the ubolts and remove the jack. simple and safe |
I've jacked from multiple locations from end to end on the axles and had no issues.
Jack stands are for sissies. And for people who have not seen what happens when a jack slips or collapses. Kinda like a big grape being stepped on.... But nastier. Talk to any ambulance driver, EMT, or morgue technician. |
Thanks for this info, this helps.
Originally Posted by mwsF250
(Post 10357732)
Jack stands are for sissies. |
To chime in.....the owners manual says NOT to jack the axle from the differential. Where on the front end do you place the floor jack? I've lifted my straight axle F350 many times by the diff without any probs, but unsure on the '06.
Originally Posted by Ian123
(Post 10358235)
How exactly are they for sissies?
(Post 10358235)
Any sarcasm can be too subtle for some... Sorry! Any person not using jack stands (or better) method to support vehicle is really flirting with the reaper. I have a couple friends that are EMT's and they've described what happens when a human head gets squished to 5% of its original diameter.
Fortunately, I have not had a vehicle land on me. We did have a close family friend have it happen. He was very lucky that it was a race car and missed his head, so he was only in hospital for a few weeks (broken bones and a couple ruptured organs). I did take a scary ride under a vehicle on which the parking pawl and parking brake both failed at same time. Coulda (shoulda?) been fatal, but I got off with only serious road rash. Now I use multiple wheel chocks as well... When I'm under car, I use jack AND multiple fixed devices. I use stacked bricks and timbers whenever possible as (properly used) they are even more stable than stands. |
On my 04 I put the jack somewhere between the leafsprings and knuckle.
Originally Posted by rattleNsmoke
(Post 10358248)
After looking inside one, I can't see any reason not to use a properly equipped floor jack under the pumpkin. |
I was hoping papa Ford didn't go to tin foil diff housings....:-roll
I'll not hesitate to jack the snot out of it next time. :-jammin |
where to jack
i normally use my floor jack under the frame, with 1 or 2 jack stands for insurance
how about for a twin i beam truck, where do i jack to have the suspension hang?
frame? can i jack from the bar under the tow hooks? |
(Post 10357732)
