How to jack truck? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How to jack truck?
Old 05-18-2011, 11:32 AM
loopsy loopsy is offline
loopsy is starting off with a positive reputation.
How to jack truck?
Hi all
I am going to do the front brakes and would like to know what the best way to lift the front is and put on stands. Im not sure what part of the front is best to use to lift. I have a 3 ton floor jack and a 10 ton bottle jack. How about the rear also?
Thanks
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
2004, F-350 diesel, 4X4, Crew, LB, Auto, 101,000 miles:
Bilstein shocks, Fumoto, Zoodad, MBRP 4 turbo back, Edge Insight, EGT probe
Old 05-18-2011, 12:43 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
the front passenger side of my 4x4 i jack it up and place a 3ton stand under the leaf spring mount and i just keep the jeck under the drivers front pumpkin but i place another 3ton stand under the drivers side just in case.
The rear i put a piece of wood i cut out to fit in my jack mount and lift the rear up by the pumpkin in the middle place two 3ton stands under the axle right below the ubolts and remove the jack. simple and safe
Old 05-18-2011, 03:15 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
I've jacked from multiple locations from end to end on the axles and had no issues.
Jack stands are for sissies. And for people who have not seen what happens when a jack slips or collapses. Kinda like a big grape being stepped on.... But nastier. Talk to any ambulance driver, EMT, or morgue technician.
Old 05-18-2011, 04:07 PM
Thanks for this info, this helps.
Old 05-18-2011, 05:23 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
Quote:
How exactly are they for sissies?
Old 05-18-2011, 05:25 PM
rattleNsmoke's Avatar
rattleNsmoke rattleNsmoke is offline
rattleNsmoke is gaining momentum as a positive member of FTE.
To chime in.....the owners manual says NOT to jack the axle from the differential. Where on the front end do you place the floor jack? I've lifted my straight axle F350 many times by the diff without any probs, but unsure on the '06.
Old 05-18-2011, 05:51 PM
maverick22's Avatar
maverick22 maverick22 is offline
maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.
Quote:
I think he was joking, read the rest of his post. Had a friend break a leg when a jack didn't hold, he's lucky that's all that was under there. I certainly use stands whenever any part of me is going to be under any part of a vehicle.
Old 05-18-2011, 05:53 PM
BolognaBlake BolognaBlake is offline
BolognaBlake is starting off with a positive reputation.
Also, what are you using?
Old 05-18-2011, 06:18 PM
Any sarcasm can be too subtle for some... Sorry! Any person not using jack stands (or better) method to support vehicle is really flirting with the reaper. I have a couple friends that are EMT's and they've described what happens when a human head gets squished to 5% of its original diameter.
Fortunately, I have not had a vehicle land on me. We did have a close family friend have it happen. He was very lucky that it was a race car and missed his head, so he was only in hospital for a few weeks (broken bones and a couple ruptured organs).
I did take a scary ride under a vehicle on which the parking pawl and parking brake both failed at same time. Coulda (shoulda?) been fatal, but I got off with only serious road rash. Now I use multiple wheel chocks as well...
When I'm under car, I use jack AND multiple fixed devices. I use stacked bricks and timbers whenever possible as (properly used) they are even more stable than stands.
Old 05-18-2011, 06:20 PM
exiled's Avatar
exiled exiled is offline
exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.
On my 04 I put the jack somewhere between the leafsprings and knuckle.
Old 05-18-2011, 06:30 PM
Quote:
I'm GUESSING the not from differential is referring to trying to jack with the factory supplied toy jack? Or maybe referring to not jacking on the pinion? Or trying to force folks to jack only one side or the other to minimize load on jack? Or to prevent folks getting run over by jacking both rear wheels up at the same time on a slope? (I'm leaning towards that one - it happens more than you think!)
After looking inside one, I can't see any reason not to use a properly equipped floor jack under the pumpkin.
Old 05-18-2011, 09:29 PM
I was hoping papa Ford didn't go to tin foil diff housings....
I'll not hesitate to jack the snot out of it next time.
Old 05-18-2011, 09:59 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
where to jack
i normally use my floor jack under the frame, with 1 or 2 jack stands for insurance
Old 05-18-2011, 11:17 PM
Gordon-0 Gordon-0 is offline
Gordon-0 is starting off with a positive reputation.
how about for a twin i beam truck, where do i jack to have the suspension hang?
frame?
can i jack from the bar under the tow hooks?
Old 05-18-2011, 11:27 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Bricks and timbers are for idiots.
X Carrier Bearings and vibrations? unlucky2.1_7.3PSD Excursion - King of SUVs 10 07-19-2016 03:14 PM
Value Question jayzad 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-27-2013 07:11 AM
Intermittent Battery Light lakerats 1999 to 2016 Super Duty 4 03-17-2011 03:40 PM
4x4 light working when it feels like it? bhamilton 2004 - 2008 F150 45 02-27-2010 03:32 PM
1992 F150 XLT 4x4 engaging problem calvinone67 1987 - 1996 F150 & Larger F-Series Trucks 5 01-20-2010 09:33 PM
Tags
1949, 1999, 99, duty, f150, f250, f350, ford, jack, jacks, locate, mount, putting, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
