89 f250 truck side trailer wire colors and what they are for
i have an 89 f250 that i am installing a 7 way rv plug, i believe it has the tow package as it has 2 plugs in the back for an oem plug in 7 way. Anyhow i couldnt find an oem plug in so i got a splice in type from napa, heres the colors i have, what do they represent, i have searched alot and also looked in the repair manual electric diagram with no real luck, thanks in advance
Black / Pink stripe (backup lamps) Green / Pink stripe Red / Blue stripe White / Red Stripe (running/tail / side marker lights) Blue / Black stripe White Red / Green stripe Yellow |
If the 88 schematics are the same as your 89, two of the wires have different
colors. Black / Pink stripe = to trailer backup lamps. Green / Pink stripe ? For a 88 shows Light Green/Orange wire = to trailer LH turn signal lamp. Red / Blue stripe ? For a 88 shows Orange/Light Blue = to Trailer RH turn signal lamp. White / Red Stripe = to trailer body marker lamps. Blue / Black stripe = to trailer electric brakes. White = From trailer ground. Red / Green stripe = to trailer brake lamps. Yellow = to trailer power. |
thank you that helps
