89 f250 truck side trailer wire colors and what they are for - Ford Truck Enthusiasts Forums
Old 04-07-2011, 09:52 AM
kawirider00 kawirider00 is offline
kawirider00 is starting off with a positive reputation.
i have an 89 f250 that i am installing a 7 way rv plug, i believe it has the tow package as it has 2 plugs in the back for an oem plug in 7 way. Anyhow i couldnt find an oem plug in so i got a splice in type from napa, heres the colors i have, what do they represent, i have searched alot and also looked in the repair manual electric diagram with no real luck, thanks in advance
Black / Pink stripe (backup lamps)
Green / Pink stripe
Red / Blue stripe
White / Red Stripe (running/tail / side marker lights)
Blue / Black stripe
White
Red / Green stripe
Yellow
Old 04-07-2011, 10:40 AM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
If the 88 schematics are the same as your 89, two of the wires have different
colors.
Black / Pink stripe = to trailer backup lamps.
Green / Pink stripe ? For a 88 shows Light Green/Orange wire = to trailer
LH turn signal lamp.
Red / Blue stripe ? For a 88 shows Orange/Light Blue = to Trailer RH
turn signal lamp.
White / Red Stripe = to trailer body marker lamps.
Blue / Black stripe = to trailer electric brakes.
White = From trailer ground.
Red / Green stripe = to trailer brake lamps.
Yellow = to trailer power.
Old 04-07-2011, 12:23 PM
thank you that helps
Ignition plug wiring F250_Super_4X4 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-19-2016 10:21 AM
1986 Ford Bronco II Wiring for Brakes tqb4life Bronco II 0 10-31-2014 02:10 PM
Help. Need fuel pump wiring harness colors. homedad 1987 - 1996 F150 & Larger F-Series Trucks 1 09-27-2013 06:46 AM
1989 Power windows and locks wiring? piersol 1987 - 1996 F150 & Larger F-Series Trucks 8 06-05-2010 06:59 PM
trailer plug wiring question bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 12 01-27-2009 08:39 AM
Tags
89, color, colors, diagramr, f250, ford, lights, obs, pink, stripe, traile, trailer, truck, trucks, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
