ford 302 to inline six conversion
i am looking to convert my ford 302 5.0 liter to an inline 300 cubic inch motor. which motor do i need to get for this conversion? the air in head or manifold? or doesnt it matter? also what is E40D a code for? please help
FINALLY SOMEONE GOIN 302 TO A 300/6! I LOVE IT!
what are the specs of your truck? e40d refers to the transmission |
STRAIGHT 6 POWER ALL THE WAY!
and E40D is the heavy duty transmission. |
i dont know the trans identification. all i know is that it is a 1990 ford f-150 reg cab long bed with the 302 engine that i blew 4 cylinders out of. i was told that the inline 6 would fit in with motor mounts wire harness and ecu. im trying to get one from a junk yard but i need to know which trans and which type of air injection i need. in the head or manifold
The trans. you have on your 302 will fit the 300.
Any transmission that came off any Ford small block engine will bolt right up to your 300. 300-6, 302 and 351 are small blocks and all have the same bell housing bolt patern. If your going E4OD, you will need an ECU that came off another that had the E4OD behind it. The transmission computer works with the engine computer on the E4OD trans. The 300 is far better than the 302 in all aspects! Much better low end power, more torque than the 302, abit less HP though. 300 = 160HP and 265ft. Torque @ ~2000RPM. 302 = 185HP and 200ft. Torque @ ~4000RPM. Can't remember the exact RPM numbers on that one. Much more durable and you can abuse it all day long, and it's only gonna ask for more! |
how do i identify if i have the E40D trans or the other one?
What does your dash gear selector say?
P R N D 2 1 = C6 P R N (D) 2 1 = E4OD (will have an OD button on the dash or steering column depending on year) P R N (D) D 1 = AOD |
its a stick. 4 speed with overdrive and reverse. also do i need to get air in head or air in manifold?
You have the M5OD (or M5R2) what ever people wanna call it.
It's a Mazda 5 speed transmission. Good transmission for everyday driving, but nothing extreme. That will go behind your 300. Just be sure since you'll have access to the transmission, replace the 3 rubber plugs on it. They like to leak and it emptys out the fluid and they burn out. |
do i need air in head or air in manifold? i dunno what this means?
That crap is emission related.
What year is your engine and truck? |
1990 truck and 1992 engine i will be puttin in
Pretty sure it's manifold AIR.
okay thank you
Yeah should be manifold.
Youl love the six |
