ford 302 to inline six conversion - Ford Truck Enthusiasts Forums
Old 03-02-2011, 07:48 PM
mustangtj02 mustangtj02 is offline
mustangtj02 is starting off with a positive reputation.
i am looking to convert my ford 302 5.0 liter to an inline 300 cubic inch motor. which motor do i need to get for this conversion? the air in head or manifold? or doesnt it matter? also what is E40D a code for? please help
Old 03-02-2011, 08:00 PM
Duct Tape Racing's Avatar
Duct Tape Racing Duct Tape Racing is offline
Duct Tape Racing is gaining momentum as a positive member of FTE.
FINALLY SOMEONE GOIN 302 TO A 300/6! I LOVE IT!
what are the specs of your truck?
e40d refers to the transmission
Old 03-02-2011, 08:04 PM
Boss94's Avatar
Boss94 Boss94 is offline
Boss94 is starting off with a positive reputation.
STRAIGHT 6 POWER ALL THE WAY!
and E40D is the heavy duty transmission.
Old 03-02-2011, 08:20 PM
i dont know the trans identification. all i know is that it is a 1990 ford f-150 reg cab long bed with the 302 engine that i blew 4 cylinders out of. i was told that the inline 6 would fit in with motor mounts wire harness and ecu. im trying to get one from a junk yard but i need to know which trans and which type of air injection i need. in the head or manifold
Old 03-02-2011, 08:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
The trans. you have on your 302 will fit the 300.
Any transmission that came off any Ford small block engine will bolt right up to your 300.
300-6, 302 and 351 are small blocks and all have the same bell housing bolt patern.
If your going E4OD, you will need an ECU that came off another that had the E4OD behind it. The transmission computer works with the engine computer on the E4OD trans.
The 300 is far better than the 302 in all aspects!
Much better low end power, more torque than the 302, abit less HP though.
300 = 160HP and 265ft. Torque @ ~2000RPM.
302 = 185HP and 200ft. Torque @ ~4000RPM. Can't remember the exact RPM numbers on that one.
Much more durable and you can abuse it all day long, and it's only gonna ask for more!
Old 03-02-2011, 08:37 PM
how do i identify if i have the E40D trans or the other one?
Old 03-02-2011, 08:41 PM
What does your dash gear selector say?
P R N D 2 1 = C6
P R N (D) 2 1 = E4OD (will have an OD button on the dash or steering column depending on year)
P R N (D) D 1 = AOD
Old 03-02-2011, 08:44 PM
its a stick. 4 speed with overdrive and reverse. also do i need to get air in head or air in manifold?
Old 03-02-2011, 08:54 PM
You have the M5OD (or M5R2) what ever people wanna call it.
It's a Mazda 5 speed transmission. Good transmission for everyday driving, but nothing extreme.
That will go behind your 300.
Just be sure since you'll have access to the transmission, replace the 3 rubber plugs on it. They like to leak and it emptys out the fluid and they burn out.
Old 03-02-2011, 08:56 PM
do i need air in head or air in manifold? i dunno what this means?
Old 03-02-2011, 08:57 PM
That crap is emission related.
What year is your engine and truck?
Old 03-02-2011, 08:59 PM
1990 truck and 1992 engine i will be puttin in
Old 03-02-2011, 09:02 PM
Pretty sure it's manifold AIR.
okay thank you
Old 03-03-2011, 01:12 PM
Yeah should be manifold.
Youl love the six
1985 F150 Inline 6 to 302 V8 Conversion matt mangano 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 12-21-2016 09:50 AM
78 Ford 4x4 motor perches Tony simmons 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-05-2013 07:58 PM
Inline 6 to V8 paintinpevs91 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 09-27-2010 07:41 PM
4.9 inline six and 5.0 V8 jimford1 General Automotive Discussion 24 06-13-2010 08:39 AM
1960 F100 motor swap punkstar 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 02-21-2010 12:00 PM
Tags
1991, 300, 302, 94, converted, f150, flywheel, ford, fuel, inline, m5od, mileage, stright, tranny, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
