No Start - CEL - Scanner will not connect
Any help would be appreciated very much...
Headed up in the mountains, lost third gear, few miles later engine quit altogether. Check Engine Light was on, cranked over fine but no fire. OBD scanner would not connect (tried 2 different ones). Seems like 3 dings followed by pause then 2 dings when key is turned to "on". All fuses where ok. |
Check the fuel bowl heater. Under the hood. I think 22 is the number iirc.
Originally Posted by going360
(Post 9959624)
Originally Posted by bad12jr
(Post 9959644)
Originally Posted by Action4478
(Post 9959739)
Check the connections to valve covers , look for loose or burned pins ...Most likely UVCH is loose or burned ...
Have you looked at any of the fuses with a meter ?
My wag is you are using the wrong scanner ... I'm Out ..... |
Check the power port and see if it works with a car charger. If it doesn't work most times the fuse is blown just barely. It powers the OBD2 port. Check with a meter for continuity
(Post 9960134)
If it all is good it could be a bad PCM.
Kind of what I'm afraid of...
Chip go bad?
