No Start - CEL - Scanner will not connect - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-12-2011, 06:46 PM
going360 going360 is offline
going360 is starting off with a positive reputation.
Any help would be appreciated very much...
Headed up in the mountains, lost third gear, few miles later engine quit altogether. Check Engine Light was on, cranked over fine but no fire. OBD scanner would not connect (tried 2 different ones). Seems like 3 dings followed by pause then 2 dings when key is turned to "on". All fuses where ok.
Old 02-12-2011, 06:51 PM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Check the fuel bowl heater. Under the hood. I think 22 is the number iirc.
Old 02-12-2011, 07:19 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Check the connections to valve covers , look for loose or burned pins ...Most likely UVCH is loose or burned ...
Old 02-12-2011, 08:56 PM
Quote:
Would this make the OBD port unavailable? I checked all the under hood and in-cab fuses and they are good. Will check again.
Quote:
Again, would this make the OBD port unavailable? The glow plugs where changed not long ago as were the harnesses. I will check them but shouldn't I be able to check the codes? Just trying to figure out why I cant get a scanner connected.
Old 02-12-2011, 08:59 PM
Have you looked at any of the fuses with a meter ?
My wag is you are using the wrong scanner ...
I'm Out .....
Old 02-12-2011, 09:00 PM
bad12jr's Avatar
Check the power port and see if it works with a car charger. If it doesn't work most times the fuse is blown just barely. It powers the OBD2 port. Check with a meter for continuity
Old 02-12-2011, 09:09 PM
Good point... the obd port powers the scanner's but it wont connect. Both of the scanners I tried have been used successfully on this truck in the past.
Old 02-12-2011, 09:12 PM
bad12jr's Avatar
If it all is good it could be a bad PCM.
Old 02-12-2011, 09:20 PM
Kind of what I'm afraid of...
Old 02-12-2011, 10:17 PM
mq1shooter's Avatar
mq1shooter mq1shooter is offline
mq1shooter is starting off with a positive reputation.
Chip go bad?
Pulling OBD2 codes without the code port Resq202 Modular V8 (4.6L, 5.4L) 6 06-27-2012 11:01 PM
ding ding sound f250 sd diesel mrpaintman 1999 to 2016 Super Duty 15 03-23-2007 09:47 PM
F150 Speedometer, odometer, computer chenz 1997 - 2003 F150 5 10-05-2006 07:29 PM
Seat belt ding ding ding F150Canuck 1997 - 2003 F150 6 02-20-2004 07:59 PM
No Power to the cab Inger Ranger & B-Series 2 06-20-2003 02:14 PM
Tags
2006, 96, car, cel, communicate, connect, expedition, ford, link, nott, obd, scanner, truck, van, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
