Originally Posted by bismic
(Post 9915247)
...Assumption - 1 stroke = 1 rpm...
and 1 RPM is half of that since it takes two revs for a complete combustion cycle. At least that's my assumption. I haven't done my high idle mod since I don't have a need to let the truck idle much, but I think it's time. |
FWIW. i remember reading a few years ago in the 7.3l forum that engine used 1/3 gal per hour at idle (not high idle)
but yeah like all the guys have said it's too long. cut it in 1/2 and drive easy. i'm the same way i don't like to drive on a cold engine (and i live in So Cal) so i take it real easy and warm it up for a few minutes every time. also i think that is your pushing more power that this is more important. |
Originally Posted by _Me2_
(Post 9920472)
Unless it is ridiculously cold, what's the point of idling for more than a minute or two and then driving easy until it's up to operating temp?
Originally Posted by Kert0307
(Post 9922223)
How cold is cold? I'm talking +20 deg F down to -15deg F. I've got a long semi steep half mile + hill to go up right after I pull out of the driveway. If I ease into it going up the hill i'll be holding up traffic. My idle time (10-15min) is one of the reasons I did the EGR delete soon after I bought the truck. When I leave from work at the end of the day I only let it high idle until the engine gets up to 80 deg (4 min) then ease into it from there.
BTW - a LONG time ago, someone put up a post that stated it is cheaper to warm up w/ a block heater than burn diesel with idling (the assumptionis that the block heater use would REDUCE the idle time). I don't live in climate that requires a block heater or extended idling very often, but the last few days we have been in the low 20's. The high idle for 3-4 minutes is a BIG help, but I think I will try the block heater (first time) tomorrow morning. |
(Post 9922306)
IMO, the key is to have the high idle mod (like you do)!
BTW - a LONG time ago, someone put up a post that stated it is cheaper to warm up w/ a block heater than burn diesel with idling (the assumption is that the block heater use would REDUCE the idle time). edit: For plugging it in i was assuming 2.5 hours and idling for 15 min. |
Originally Posted by raptor131
(Post 9914498)
this would be a great suggestion for Myth Busters. The only way to know would be to place some sort of "flow meter" in the fuel line, or to drain the tank and place only 1 gallon of fuel, and seeing how long it takes to run it out of fuel, but no one who owns a diesel is going to let a 6.0 run out of fuel on purpose so flow meter or nothing, call Myth Busters!
Originally Posted by EddieEX10
(Post 9923457)
Fill it to the top, let it idle for an hour and then fill it again then you will know the exact amount without having to run it dry.
i still say at low idle .5 gph is too high of a number IMO...
its hard to measure that small of flow rates without precise equipment and i doubt every superduty is equipped with the right senors for AE(or any plug in software) to be very accurate. its more or less a ball park figure. |
IF you can get the factory mass-fuel-desired and fuel-volume-desired numbers from the PCM, it's not terribly difficult to FIGURE a decent assumption.
The problem is that those two values are excessively difficult to pull out correctly. Especially if the engine is running a tune of any kind. -blaine |
It all depends on how cold is it. Block heater only gets you 120 degrees water and the rest is cold, oil for example. So, in our temps at -20 C oe -30, yeah more idle time is required. Thats -30 F as well. So, idle of 15 minutes dont warm much. I am seeing easily 1 gal an hour on idle, faster and more with higher idle due to temps in the cold, hi idle mod overide at 1250 is likely more than that...
I suspect that with all the EPA considerations, the 6.0L is designed to use more fuel at idle than previous year models in an effort to get heat in the engine more quickly. This will increase the speed at which the emissions get under control. Just a guess though.
Originally Posted by mhoefer
(Post 9924694)
I think regular extended idling is a very bad for modern light high speed diesels. Sometimes there is a good reason as when I had a diesel (Landcruiser) up north and let it idle all night at 50 below, but I had a hand throttle and brought the rpm to around 1400.
I never idled my 97 power stroke for long even with a cold minus 20 start, this truck had an auxiliary ecm and set that for idle at around 1200. Idled just long enough to take the cold out then drove easy - under 2000 rpm. With my 2004 i live in a mild area with occasional frosty mornings, I start let run about 15 to 20 secs so the oil is going around and then drive - under 2000 rpm till thoroughly warm. People behind me hate me for being slow - too bad for them. Well over 300,000 Km on my old power stroke and engine still ran like new. My 04 has just over a 100,000 Km and runs great. (miss the old manual glow plugs and hand throttle) |
I recently bought a Scangauge II and it reports Gallons Per Hour on my 2005 PSD. The gauge reports injector pulse with and needs to be calibrated for accuracy. I filled my tank to the brim. When I refill and adjust gallons used reported by the SC II vs. actual gallons, I should be able to report GPH at normal and SEIC up idle.
I calibrated my Scangauge II today. Its predicted fuel usage was only 3.5% high. After correction, it reports my 2005 PSD:
.41 GPH at idle .60 GPH at SEIC high idle Winterized fuel + Power Service anti gel at +32F I bet that's very close to reality. |
