7.3 idi intake..... custom.... pictures!
i fabed up a custom intake for my factory turbo idi, i used a 3.5" bend cut as a slash cut then a 1.5" piece of straight 3.5" welded onto it to go into the turbo, i set it to the right angle and cut a 90 degree piece of four inch to fit it so that it would line up with where the radiator overflow and washer fluid res sit, welded those up. i moved the rad overflow over to the other side, it fit nicely between my battery and heater fan right in front of my starter solenoid, i bolted the washer fluid reservoir to my hood hinge on the drivers side on the back side of the fuse/relay box, ran a piece of straight 4" from my 4" bend and onto a napa 6637 filter. welded a 1" piece of stainless onto the intake for my oil hose. works awesome, added a brace bolted to the filter head brace to make sure the intake is always clear of the injector lines.... if anyone is interested in pictures parts or instructions, let me know.
a few more pics in my album... check it out! https://www.ford-trucks.com/forums/p...ictureid=59371 |
You kidding? A post like this is worhless without pictures! Post 'em up! Put 'em in your gallery an post links to them so we can see your work!
Yeah, where's the pics?? Sounds nice but a picture's worth 1,000 words.
Post some pics!!! Sounds great!!!
HECK YES WE ARE INTERESTED IN PICS LOL!!!
Looks sweet!
Ah, nice work. Much better with pic. Is the boost any higher/EGT's lower??
Nice Job! Pics sure did help lol
i build boost quicker, helps in the lower end, i can tell a difference going up hills around town, i dont lose boost as fast during shifts. i havent run a big enough load to tell a difference in egt's im sure they will improve though.
Not bad, I considered doing something like that but I wanted to do 4" all the way and the bend there was too sharp for that. I just flipped my filter mount and ran it to the passenger side fender.
http://i28.photobucket.com/albums/c2...IM000049-1.jpg |
looks like that flip filter mount makes for easier filter change?
Are the batteries in the way for good air flow?
Originally Posted by ghunt
(Post 9917286)
Originally Posted by GHeTTo JOe
(Post 9919335)
Also the battery wouldn't affect airflow...it brings in air all around the filter.
Originally Posted by Coalroller
(Post 9919933)
ghunt... what coupler did you use for that at the turbo inlet? is it 2.75"-4" or a 3"-4"?
Anyway, the way I got around it was to wrap some 16 gauge aluminum around the inlet of the turbo and silicone it on to give it a little more diameter. Another option is do the same thing with some rubber or something like that- just something that will keep the coupler from fitting so loose. |
(Post 9922316)
I used a 3-4 because 2.75-4 is almost impossible to find. Why they used a 2.75 inlet on the turbo I will never know...
Anyway, the way I got around it was to wrap some 16 gauge aluminum around the inlet of the turbo and silicone it on to give it a little more diameter. Another option is do the same thing with some rubber or something like that- just something that will keep the coupler from fitting so loose. thanks man! |
