7.3 idi intake..... custom.... pictures! - Ford Truck Enthusiasts Forums
Old 02-01-2011, 11:09 PM
tinsleystyle tinsleystyle is offline
tinsleystyle is starting off with a positive reputation.
Talking 7.3 idi intake..... custom.... pictures!
i fabed up a custom intake for my factory turbo idi, i used a 3.5" bend cut as a slash cut then a 1.5" piece of straight 3.5" welded onto it to go into the turbo, i set it to the right angle and cut a 90 degree piece of four inch to fit it so that it would line up with where the radiator overflow and washer fluid res sit, welded those up. i moved the rad overflow over to the other side, it fit nicely between my battery and heater fan right in front of my starter solenoid, i bolted the washer fluid reservoir to my hood hinge on the drivers side on the back side of the fuse/relay box, ran a piece of straight 4" from my 4" bend and onto a napa 6637 filter. welded a 1" piece of stainless onto the intake for my oil hose. works awesome, added a brace bolted to the filter head brace to make sure the intake is always clear of the injector lines.... if anyone is interested in pictures parts or instructions, let me know.
a few more pics in my album... check it out!
Old 02-01-2011, 11:37 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
You kidding? A post like this is worhless without pictures! Post 'em up! Put 'em in your gallery an post links to them so we can see your work!
Old 02-02-2011, 08:15 AM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Yeah, where's the pics?? Sounds nice but a picture's worth 1,000 words.
Old 02-02-2011, 08:36 AM
vfelix702's Avatar
vfelix702 vfelix702 is offline
vfelix702 is gaining momentum as a positive member of FTE.
Post some pics!!! Sounds great!!!
Old 02-02-2011, 06:02 PM
Coalroller's Avatar
Coalroller Coalroller is offline
Coalroller is starting off with a positive reputation.
HECK YES WE ARE INTERESTED IN PICS LOL!!!
Old 02-02-2011, 06:47 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is online now
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Looks sweet!
Old 02-02-2011, 08:14 PM
Ah, nice work. Much better with pic. Is the boost any higher/EGT's lower??
Old 02-02-2011, 08:26 PM
Coalroller's Avatar
Nice Job! Pics sure did help lol
Old 02-03-2011, 12:43 AM
i build boost quicker, helps in the lower end, i can tell a difference going up hills around town, i dont lose boost as fast during shifts. i havent run a big enough load to tell a difference in egt's im sure they will improve though.
Old 02-03-2011, 12:18 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
Not bad, I considered doing something like that but I wanted to do 4" all the way and the bend there was too sharp for that. I just flipped my filter mount and ran it to the passenger side fender.
Old 02-03-2011, 07:52 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
looks like that flip filter mount makes for easier filter change?
Old 02-03-2011, 08:09 PM
BlueOvalBud's Avatar
BlueOvalBud BlueOvalBud is offline
BlueOvalBud is starting off with a positive reputation.
Are the batteries in the way for good air flow?
Old 02-03-2011, 09:58 PM
Coalroller's Avatar
Quote:
ghunt... what coupler did you use for that at the turbo inlet? is it 2.75"-4" or a 3"-4"?
Old 02-04-2011, 12:49 PM
ghunt's Avatar
Quote:
Sorta...lot easier to get a filter wrench on but some of the other stuff around it can get in the way.
Also the battery wouldn't affect airflow...it brings in air all around the filter.
Quote:
I used a 3-4 because 2.75-4 is almost impossible to find. Why they used a 2.75 inlet on the turbo I will never know...
Anyway, the way I got around it was to wrap some 16 gauge aluminum around the inlet of the turbo and silicone it on to give it a little more diameter. Another option is do the same thing with some rubber or something like that- just something that will keep the coupler from fitting so loose.
Old 02-04-2011, 10:03 PM
Coalroller's Avatar
thats what i figured... i have a a bunch of those rubber/silicone adaptors that are from the inside of air filters that i'll pry through on there like you said.
thanks man!
Project-Converted 92 f150 to f250 running gear aharleycpl 1987 - 1996 F150 & Larger F-Series Trucks 6 04-07-2016 10:30 PM
How To Get Rid Of Smog Pump Bracket FordFETruck '80-'86 HOWTO's 5 03-09-2015 02:58 PM
72 F-250 4X4 Power Steering - Instructions with Pictures tpdaniels 1967 - 1972 F-100 & Larger F-Series Trucks 23 03-01-2015 07:16 PM
hx35 redneck engineering gingrass179 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 61 12-15-2012 11:30 PM
6637 filter on banks sidewinder turbo helifixer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 02-13-2010 12:26 AM
Tags
1994, 2003, 73, 73idi, custom, f350, ford, idi, intake, pics, pictures, sale, top, trucks, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
