Fuel Pump Relay Location
Okay, I have searched high and low and found two different answers for the location of the fuel pump relay on a 2002 F250 SD 4x4 with a V-10. One says it is under the hood in the drivers wheel well and one says that it is integrated into the Central Junction Box and is non-serviceable, meaning the whole CJB needs to be replaced$$$.
Can anyone here give me a definitive answer on the location? Thanks. |
I believe an 02 is the same as this. Hope this helps. Good luck.
https://img513.imageshack.us/img513/...pumprelay1.jpg https://img831.imageshack.us/img831/...pumprelay2.jpg |
Pulled the radio and there is not a relay panel behind it. Any other suggestions? Are the relays embedded in the CJB?
