Fuel Pump Relay Location - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-13-2011, 11:44 AM
rlshroyer rlshroyer is offline
rlshroyer is starting off with a positive reputation.
Okay, I have searched high and low and found two different answers for the location of the fuel pump relay on a 2002 F250 SD 4x4 with a V-10. One says it is under the hood in the drivers wheel well and one says that it is integrated into the Central Junction Box and is non-serviceable, meaning the whole CJB needs to be replaced$$$.
Can anyone here give me a definitive answer on the location?
Thanks.
Old 01-13-2011, 12:14 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
I believe an 02 is the same as this. Hope this helps. Good luck.
Old 01-15-2011, 04:12 PM
Pulled the radio and there is not a relay panel behind it. Any other suggestions? Are the relays embedded in the CJB?
2004 f250 5.4 engine, fuel pump relay location landscaper62 1999 to 2016 Super Duty 6 12-18-2016 12:21 PM
fuel pump relay location? vmj 1999 to 2016 Super Duty 3 11-19-2011 10:25 PM
1994 4.9 5spd fuel pump relay positon danos94 1987 - 1996 F150 & Larger F-Series Trucks 4 07-22-2010 01:49 AM
fuel pump relay location csuteau 1999 - 2003 7.3L Power Stroke Diesel 3 08-19-2008 05:24 PM
Fuel pump relay location 97Centurion Bronco II 14 04-28-2005 01:34 AM
Tags
2001, 2002, 250, 73, diesel, f250, f350, ford, fuel, hopw, location, pump, pumps, ram, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
