Check Engine light flashing randomlly driving
'89 F150 300 Straight 6, C6, 62k miles
Been doing it for a couple days now, driving down (on the highway only) the Check Engine flashs randomlly, sometimes even looks like the bumps makes it light up, will stay on for a solid few seconds, then off, then flash again. Seems to stay on solid whenever you really put your foot on the gas. Whenever theres a good load on the engine. Let off, light turns off, driving along @ 55mph flashes randomlly? Could it be a loose contact/connector for something since it seems that the bumps affect it? When I get off the highway, it's off and never comes on, not even with the bigest bump. |
Have you pulled codes? Or get a friend or someone to sit in the driver seat while you wiggle the wiring.
I don't have a codes reader. Not right now anyways... never bother getting one, never had a computer controled engine before 7 months ago...
But the light is never on parked. |
Mine does that, it's my EGR sensor malfunctioning. IDK if that is the problem, but it could be it! ^_^
Ford Fuel Injection » How To Run a Self-Test Here is a link to instructions for getting any trouble codes without a code reader. The CEL does not have to be on for there to be trouble codes.
Might be worth doing. |
my 95 bronco did the same thing going down the highway...inbewteen 55-65 the check engine light would come on until i slowed to about 45...do the self testvery easy to do...but in the test i found it easier to not do the slash marks...whatever works best for you though
My stang was doin that, was idle air control sensor . Best thing to do is self test like lazy k said
