adjusting the carb on 390
I want to set the mixture screws on an edelbrock 750 for my 390. Everything i've read has people saying you turn one at a time till it bottoms out and the engine runs rough/stumbles, then turn it back out till max idle and do the same for the other screw....Well when i do this my engine doesn't stumble, it idles higher, what's the deal here?
You probably have a vacuum leak.
http://www.edelbrock.com/automotive_...ers_manual.pdf
Page 6. Screw IN the idle mix screws, it LEANS the mix. That means if you are bottoming them out, and the idle INCREASES, the mix is already way too rich. Are you sure the choke is all the way open when you're doing this? |
I'll agree that i used to have a vacuum leak. It was a bad brake booster and actually, when i changed it out, is when this started happening. It used to idle down when i bottomed the screws. Once i changed the booster (old one would idle engine down pretty low whenever i'd brake), this occurred.
Yes the choke is open, i let the engine get up to running temp to do this. The only thing i don't do is set the actual idle itself by tach because i don't have one so i just guessed and it sounds about 800-900. |
Hmm... depending on your initial timing, you might have the throttle plates open far enough that you're running on the primary circuit and not just the idle circuit.
Any ideas as to what i should do? new carb? have someone rebuild this one and tune it themselves?
Originally Posted by NW 150
(Post 9690498)
It's been taken apart and cleaned out a few months ago, but could have been done better. I don't know where to take it to though.
