adjusting the carb on 390 - Ford Truck Enthusiasts Forums
Old 12-14-2010, 09:37 PM
NW 150's Avatar
NW 150 NW 150 is offline
NW 150 is starting off with a positive reputation.
I want to set the mixture screws on an edelbrock 750 for my 390. Everything i've read has people saying you turn one at a time till it bottoms out and the engine runs rough/stumbles, then turn it back out till max idle and do the same for the other screw....Well when i do this my engine doesn't stumble, it idles higher, what's the deal here?
Old 12-15-2010, 12:06 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
You probably have a vacuum leak.
Old 12-15-2010, 07:45 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
http://www.edelbrock.com/automotive_...ers_manual.pdf
Page 6.
Screw IN the idle mix screws, it LEANS the mix. That means if you are bottoming them out, and the idle INCREASES, the mix is already way too rich.
Are you sure the choke is all the way open when you're doing this?
Old 12-15-2010, 07:54 AM
NW 150's Avatar
I'll agree that i used to have a vacuum leak. It was a bad brake booster and actually, when i changed it out, is when this started happening. It used to idle down when i bottomed the screws. Once i changed the booster (old one would idle engine down pretty low whenever i'd brake), this occurred.
Yes the choke is open, i let the engine get up to running temp to do this. The only thing i don't do is set the actual idle itself by tach because i don't have one so i just guessed and it sounds about 800-900.
Old 12-15-2010, 08:19 AM
Krewat's Avatar
Hmm... depending on your initial timing, you might have the throttle plates open far enough that you're running on the primary circuit and not just the idle circuit.
Old 12-15-2010, 03:45 PM
NW 150's Avatar
Any ideas as to what i should do? new carb? have someone rebuild this one and tune it themselves?
Old 12-15-2010, 03:58 PM
Bear 45/70's Avatar
Quote:
99% of the carbs replaced have nothing wrong with them. All they need is a proper adjustment or a rebuilt and a proper adjustment.
Old 12-15-2010, 04:55 PM
NW 150's Avatar
It's been taken apart and cleaned out a few months ago, but could have been done better. I don't know where to take it to though.
New carb fade to stall at 750 rpm reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 04-11-2015 08:56 PM
Motorcraft 2100 carb stumble Old Brown F250 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 02-12-2014 04:59 AM
390 15.5 in Hg idle mixture screws make no difference 76 F-150 390FE FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 05-14-2006 12:01 AM
Whats the problem? ScottJM FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 02-11-2005 10:44 AM
Stumble, hesitation, miss teds74ford Ford Inline Six, 200, 250, 4.9L / 300 2 08-08-2004 07:02 AM
Tags
1975, 390, 750, adjust, carb, carbuerator, carburetor, choke, edelbrock, f250, fe, ford, rough, runs, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
