Uplifter switch wires?
I have the uplifter switches and have no idea where the hook up wires are for this all i found under dash on left side was about 10 skinny wires capped and not the right colors as book shows ???
drop the fuse block & look up there
Fuse Block on Passenger side ??
the fuse block on the drivers side
1 Attachment(s)
If yours is the the newer Superduty the fuse box is on the pass side & the old location under the steering wheel is just an access panel. The upfitter wires are above the park brake release & you can remove that access panel for more room /Light.. See the below PDF for the pictures of the wires & their location...
Thank _You Found them you the man
Originally Posted by My Skilz
(Post 9563343)
we knew you could do it, how much skin did you lose? Gigger
