Uplifter switch wires? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 11-14-2010, 02:17 PM
My Skilz My Skilz is offline
My Skilz is starting off with a positive reputation.
I have the uplifter switches and have no idea where the hook up wires are for this all i found under dash on left side was about 10 skinny wires capped and not the right colors as book shows ???
Old 11-14-2010, 02:19 PM
GIGGER's Avatar
GIGGER GIGGER is online now
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
drop the fuse block & look up there
Old 11-14-2010, 02:33 PM
Fuse Block on Passenger side ??
Old 11-14-2010, 03:29 PM
GIGGER's Avatar
Posting Legend
the fuse block on the drivers side
Old 11-15-2010, 09:44 AM
Byram's Avatar
Byram Byram is offline
Byram has a good reputation on FTE.Byram has a good reputation on FTE.
If yours is the the newer Superduty the fuse box is on the pass side & the old location under the steering wheel is just an access panel. The upfitter wires are above the park brake release & you can remove that access panel for more room /Light.. See the below PDF for the pictures of the wires & their location...
Old 11-15-2010, 08:40 PM
Thank _You Found them you the man
Old 11-15-2010, 08:42 PM
Byram's Avatar
Quote:
No Problem
Old 11-15-2010, 08:49 PM
GIGGER's Avatar
Posting Legend
we knew you could do it, how much skin did you lose? Gigger
2008 F-450 Super Duty 6.0 Uplifter Switch Herb0611 1999 to 2016 Super Duty 3 02-23-2015 06:50 AM
Adding Uplifter Switches moreammo 1999 to 2016 Super Duty 10 01-04-2015 12:00 AM
#3 uplifter wired? KDAVID1 6.0L Power Stroke Diesel 13 04-06-2014 03:42 PM
uplifter switchs 2008 super duty claxton1 6.4L Power Stroke Diesel 9 11-04-2012 02:09 PM
upfitter or uplifter switches RadarRick Electrical Systems/Wiring 6 01-14-2008 08:34 PM
Tags
2010, 2011, box, duty, f150, f350, ford, fseries, fuse, hook, super, switches, trucks, uplifter, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
