howdy all,
i put yet another heater control/ hot water shut off valve on my ranger. |
Originally Posted by Volvo92906
(Post 8178336)
Would you mind posting up a pic of that somewhere? I was thinking of doing something with mine, mainly just getting big semi type mirrors, because when someone is in the passenger seat I always have to tell them to move so I can see. Its quite annoying and they do rattle out of view a lot too. Thanks.
Originally Posted by FORD RANGER
(Post 8179923)
howdy all,
so what is this i hear about stepping up the timing from 9 to 12? Better gas mileage got my attention and I was wondering what motor this is done on. I just ordered a streetfire coil for a mustang for my truck and I'm waiting for its arrival. I put MSD cap and rotor and 8.5mm wires on it today but i'm thinking about swapping them for 9mm. we'll see.
I sanded and repainted my wiper arms and re glued the rear view mirror tab on the windshield
Originally Posted by biguglylongbed
(Post 8180261)
nothing.....but the day isn't over, yet
Fixed the seat position wire that was broken. Added stiffer wire, and it's like new again. Wife spent a few hours and about 4 cans of Spot Shot to clean the upholstery. Apparently the PO used to roll around in a grease pit before driving home at night.
Fixed the tailgate handle, and began on scrubbing out the interior.
Fixed my tailgate,handle was sticking so took it apart and lubed it up
just about got the four speed out of donor, took hood off the flatbed. trying to organize the job....prolly swap steering columns, next
Changed the oil in my commuter(96 probe)
Changed the oil in the 86 and put on a Powerstroke oil filter for 1 more qt capacity, changed the glow plugs,put the air intake tube back on, rotated the tires |
Did a complete cleaning on my truck, inside and out. Next weekend I need to put compound or wax on it.
Had the truck aligned at the shop after I installed the f350 coils in the front. No more \ /.
Originally Posted by BCHauler
(Post 8187846)
(Post 8180261)
Before that my timing was at 8*, not only did I have no power but I was getting 10mpg. For a while I had it at 15* running off regular gas, and when I put it back to 13* I noticed a reduction in power and my gas gauge drops slightly faster, even when driving at a constant (more fuel efficient, I might add) 2000rpm. Other than that I added coolant, cause she boiled over good and lost a lot the other night. I also plugged in my block heater and put a thing that turns the power on to it remotely so I can turn it on right when I get up without having to go to the cold outside to plug it in. It's snowing so it be that time. |
