all work cancelled this weekend on trucks, barrett jackson is on.lol
It's been too bloody cold here the last week to do a thing lol
Originally Posted by juni88126
(Post 11321743)
Well worked at getting the motor out of the truck got the exhaust cut off and the drive shaft removed. once the coverall dry out a bit, i will go out and get the tranny crossmember, tranny mount and the motor mounts unbolted then out it comes. Any one want to buy this 460 and 2wd e40d it is taking up space that i need. :D
The 95 was doing some squeelin from the engine and I discovered the idler pulley was bad so I replaced it and the belt. The pulley lasted 10 years and about 35000 miles. I had replaced them both when my friend had the truck in 2002 and put a belt on it then. Belt is still good so I kept it for a spare. Next week it front shocks and fresh paint on the shock towers.
I went from this:
http://a2.sphotos.ak.fbcdn.net/hphot...98750623_n.jpg To this: http://a7.sphotos.ak.fbcdn.net/hphot...25309029_n.jpg |
yesterday, mouned my rf seat and the center seat. also took my cluster out to change bulbs. dropped the coulmn to fix the loose bushings
today, mounted lh seat, installed bushings on steering column, wiring, lots and lots and lots of wiring, i ran my wires for my 2 pillar gauges and my long range kc's , installed a fuse panel under the hood for the multiple feeds into the truck, upgraded my charge wire from the stock 8 gauge to a 4 gauge with a 140 mega fuse . either way i am fing tired! |
well i was out giving money to court and getting breakfast. and thought hmmm my reverse lights dont work so i went and got me some new lights so i can see in the dark. also my headlights are comlete crap so i got some new eyes for the front to. got a sweet new shift knob a while ago. but i moved it to the transfercase today and put the old aftermarket one back on the transmison as it was taller and fit me better
[IMG]http:/http://i1227.photobucket.com/albums/...05539603_n.jpg[/IMG] [IMG]http:/http://i1227.photobucket.com/albums/...41406626_n.jpg[/IMG] [IMG]http:/http://i1227.photobucket.com/albums/...26554134_n.jpg[/IMG] [IMG]http:/http://i1227.photobucket.com/albums/...67059543_n.jpg[/IMG] |
I might have another shifter stick laying around that you can have. Yours looks like it has seen better days Cyborghunter. Which tranny do you have?
Got a 130 amp 3G alternate for the truck and some new brake parts for the rear.
Got my 2" coil spring spacers in the mail. Now I have to wait till sat to put them and my 3" blocks in
Post up some pics after you do it Midnite.
Before and after pics will be in my build thread when done
Backed into a parked tractor-trailer, passenger side hit trailer at side rail, and above my tail-lite. Creased it. :-arrgh :-X16Was backing up to unload, mirrors fogged up, shoulda known. G.O.A.L. Geez.:-huh
finished the saginaw PSP swap, put in my PowerMaster 140amp alt and removed the bed to get ready to finish up the rear-end.
Going to start tomorrow on cleaning up and preping the frame, bolting in c-notch, painting frame, new hangers front and rear, new spring plates and 5/8's u-bolts. |
Originally Posted by Midnite1987
(Post 11328981)
