Popped the hood to check oil this morning and saw the serpentine belt was starting to shred. Tensioner was coming apart. It got a new tensioner and belt. Picked up the axle seals while I was at it.
got my intake in i ordered off ebay. dont like how it site ontop of the fuse box, the filter hits the hood... going to try n modify it and get rid of the factory tubes to keep the filters more centered in the engine bay
http://a8.sphotos.ak.fbcdn.net/hphot..._6213028_n.jpghttp://a7.sphotos.ak.fbcdn.net/hphot..._7917250_n.jpg it started storming halfway through so i didnt try for a better pic lol |
I just put locking gas caps on my truck (yea ok so theres anti theft for the tanks) but the tanks are reciently being left open slightly and its really suspicious as gas will pour out for what ever reason so i put them in to stop this crap...
also picked up fuel cleaner stuff for the entire injection system so ill be putting that in soon before next fill up :) |
Originally Posted by Midnite1987
(Post 10621661)
I'm currently in the process of removing the stock tape player in my 96 but even with the special keys in the 4 holes it still does not want to come out. I've popped the clips and the head unit wiggles and comes out about a quarter inch but it feels like its snagged on something in the rear.
I'm about 5 minutes from using a hammer to turn the tape player into little plastic pieces to see if that will help get it out. I know it is supposed to just slide out once the clips are pushed back with the the u shaped keys but it doesn't. Any advice? Other than that I'm going to detail the interior and maybe wash it if these rain clouds move along. |
(Post 10621661)
I made a code reader extension to reach into the cab, because I'm sick of spending money on her, I'll use the saved money for beer...damm its hot out. :p
http://i51.photobucket.com/albums/f3...codereader.jpg |
Originally Posted by WoodGrain
(Post 10622532)
Washy washy... Then rainy rainy... :-arrgh
(Post 10622532)
Originally Posted by TexasGuy001
(Post 10626471)
Try reaching through the glove box and pushing it out while holding the key tools out to the sides.
OR....In my case....Push the U shaped pieces in till you feel a ever so slight CLICK....Then spread them apart from one another, and pull.....Might have to get someone to do as TG said.... |
Originally Posted by KevinGnWV
(Post 10624194)
I didn't have the keys and used coat hangers. Like yours it got stuck part way out. I just had to adjust the hangers while putting pressure on the radio. You can feel each corner pop loose as you work your way around. Once all 4 corners pop loose it should slide out then.
Originally Posted by hammerhead90
(Post 10623546)
The stock air box is actually already more than the stock motor needs. As Texas said by just adding the intake tube from a 460 or I6 truck will be the best improvement available. Then you can do like a few of us have done, and just get a drop-in k&n filter from an auto parts store
I went to Menards and got 37 2x4's, 6 4x4x10's and 34 60lb bags of concrete and watched her squat!!!!
Originally Posted by 86F150302
(Post 10624260)
