alright thanks for the replys guys..the AC is put on hold for now..i have a popping in the front end now when hittin the brakes and also just hittin the gas ill feel it pop..thats a bit more important to figure out then my ac problem right now..dont wana loose controle of the ol girl driving one day.
Done the ford tauras dome light install. It looks great just like factory i was even forunate enough to buy a light grey one to match my interior. will take pics in a few days. If you are thinking about doing this be prepared to cut the extra piece of plastic that sticks up on the back side of the light for a good flush fit.
Got another tank selector valve from pull-a-part. I also got lucky and scored a wood overhead switch panel from a centurion interior
Determined that my new noise is coming from the right rear axle bearing. Since I've changed the bearing once before it's time to dig the spare rear out of storage and get ready to swap it out.
Got my alignment! :-jammin
And also realize my steering gearbox is worn out pretty badly. Replace or have it rebuilt/upgraded... |
Run a compression and a tune up. Compression was 140 psi to 150 psi across the board.
Pretty much just drove it. Pulled an N14 out of a Steiger 9370 at work, though. Tore it down to replace a broken crank. It was split right down the middle between #3 and #4 journals. Also spun a main bearing, so the block is pretty much trashed and the cam lobes were almost all destroyed. Very cool. Not an everyday sight. Turns out the #3 piston and rod were installed 180* off and wasn't allowing oil to the main bearing or the camshaft. Carnage. Pictures later. Very cool. By the time I got off work, though, it was too dang hot to do anything to Clyde and my boy was in a good mood when I got home so I just played with the little man.
finished mt exhaust
Started the long process of final checkups before a road trip up to the cabin.
I did notice this though... http://i145.photobucket.com/albums/r...672650x488.jpg Anyone else see a big chunk of leaf missing? Making me very nervous about driving 3 hours 1 way with wood and other stuff in the back. :( Gotta make a run to the salvage yard tomorrow and see what they have around. |
Started Operation clean bed tarp last night.....Cleaned the cab out today...ANd getting my windows tinted tomorrow...
Finished setting the new rear step bumper in place, began troubleshooting the extreme hesitation again,,checked the TFI for obvious defects, none found, rotor and cap and ignition system connectors look good. Went to the zone and picked a fuel pressure test kit.
Originally Posted by Marine5811
(Post 10544869)
Pulled the rear tires and wheels off and took the over to Porter tire to mount the new
35x15x12.5 Maxxis Bighorns. Put them back on the truck. |
Got my windows retinted to 5%......And picked up some Frost King A/C ductwork insulation......Now to find a suitable floormat....
Started it...
It's been sitting in ghetto desert camo (Primer) for a year now, awaiting funds for a clean paint job. Needed to make sure the seals dont dry up on me, so I flashed it and brought it up to operating temp. Only 3 revolutions and it fired up. Getting sick of looking at it stationary, under a truck cover. Almost tempted to roll on rusteoleum and drive the beast... but then I remember how much time I spent block sanding it and I cant let myself do that. |
