Pretty sweet looking build so far... I must say...
Originally Posted by SavageNFS
(Post 13306250)
I think it looks great! Keep up the good work!
P.S. I have the same grinder...works fantastic. Worth every penny.
Originally Posted by Tomahawk
(Post 13308644)
@Savage - Metabo + the original "Slicer" disk = Awesomeness! I love it.
Off topic question about your grinder you love so much. I see that that style is their "Basic Series", but they list quite a few different ones as well as the some of the more expensive models with other features. Now, I don't mind spending money on quality tools, but at the same time, there is no need to pay for fancy options if they are really not needed. Which P/N do you have. I was looking at the Metabo WP8-115 for $130 or the Metabo W 820-115 for $66. |
Originally Posted by Aaron-71
(Post 13876802)
Originally Posted by AK FORD GUY
(Post 13876955)
First and foremost, that truck looks awesome. :-drink I have a soft spot for bumpsides. I have owned 3 of them and really regret selling the 70 F250 4x4 I had. Very low mile original truck. It was a State Plow Truck and had just over 70K on it, but had been wearing the plow it's whole life.
Off topic question about your grinder you love so much. I see that that style is their "Basic Series", but they list quite a few different ones as well as the some of the more expensive models with other features. Now, I don't mind spending money on quality tools, but at the same time, there is no need to pay for fancy options if they are really not needed. Which P/N do you have. I was looking at the Metabo WP8-115 for $130 or the Metabo W 820-115 for $66. Here's the grinder info.... http://i1197.photobucket.com/albums/...224_141541.jpg Here is the link to the current (newer) model. Metabo Service Portal Cheapest place I can find it online. You may be able to get a better deal at your local welding supplies shop. Metabo 6.00160.42 6-inch Electronic Angle Grinder It has two safety features I like, soft start - so it won't jump in your hands when you switch it on, and restart protection - in case you loose power and the slide switch is in the "on" positon it won't restart. I like the slide switch on top instead of a dead mans paddle switch on the bottom, it's less likely to get hit and powered on accidentally. The newer version has a torque limiting clutch. It's a little more expensive, but the safety features are worth it. Aaron and AK, have a Merry Christmas! http://i1197.photobucket.com/albums/...eChristmas.jpg |
All I can say is AWESOME! I had a 70 4x4 390 man trans bump and miss the hell out of it, it had no power steering and gave this 18at the time (man im old!) kid a hell of a time steering that tank, knowing now how easy it is to convert em to power steering I miss it even more! nice job. I understand lowering it, it probably didn't have the best road manners.
Thank you for all the info Tomahawk.
You have a Merry Christmas and a safe New Year as well my friend. :-drink |
Awesome job Gavin! Enjoy the time in the shop this week. You deserve it. Merry Christmas!
Originally Posted by Scooters77
(Post 13877442)
(Post 13877547)
(Post 13877635)
Merry Christmas all! |
I always try to keep the guards on my angle grinders now, I nearly lost my left index finger just above the knuckle when a cutting wheel flew apart on me last year, stupid me, no gloves on.
Nice looking rig BTW. :-jammin |
Thanks Shane, sorry I missed your post. Heavy leather gloves are a must when running a grinder.
Update. First I would like to say thanks to Gerry (GIGGER) and Paul (Hdslider) for helping me with the ring and pinion setup, you guys are the best! The truck sat for a long period of time when PO1 had it and the ring gear became badly pitted on part that wasn't submerged in lube oil. http://i1197.photobucket.com/albums/...321_215127.jpg The bearing surface for one of the spiders was also badly pitted so I had to get a new carrier. http://i1197.photobucket.com/albums/..._/DSC_4253.jpg New carrier, all cleaned up! http://i1197.photobucket.com/albums/...710_191252.jpg PO2 did a lousy job of welding and getting the shock mounts on straight, so I fixed that. http://i1197.photobucket.com/albums/...0/DSC_4252.jpg I got the axle housing primed and painted. http://i1197.photobucket.com/albums/...703_195742.jpg Got the axle on the workbench, ready to dump in some gears. http://i1197.photobucket.com/albums/...0/DSC_4272.jpg I machined an aluminum disk to press on the carrier bearings, it got used a lot. I needed something to push the bearings past the end of the hub and not press on the cage, it worked great for at least a dozen times. http://i1197.photobucket.com/albums/...0/DSC_4273.jpg The old carrier worked great for pressing on the inner pinion bearing. http://i1197.photobucket.com/albums/...0/DSC_4279.jpg The carrier bearings getting pressed on, the old bearings were in good shape so I used them while doing the setup. http://i1197.photobucket.com/albums/...0/DSC_4276.jpg First try at a contact patch.....not so good. http://i1197.photobucket.com/albums/...714_134726.jpg Taking off the bearings, change shims, press the bearings on.....repeat http://i1197.photobucket.com/albums/...0/DSC_4530.jpg Getting closer... http://i1197.photobucket.com/albums/...714_133742.jpg ....and a good contact patch. http://i1197.photobucket.com/albums/...804_182421.jpg I added a drain plug to the diff cover because I want to look at the ring gear teeth and change the fluid and not regoo the cover....yes, I am lazy. http://i1197.photobucket.com/albums/..._/DSC_4329.jpg http://i1197.photobucket.com/albums/..._/DSC_4328.jpg http://i1197.photobucket.com/albums/..._/DSC_4333.jpg http://i1197.photobucket.com/albums/..._/DSC_4332.jpg I got the drum brakes rebuilt......that is so much easier to do on a workbench. New drums, the old shoes had no wear, new bearings and seals for the hubs. Everything painted ready to put back together. http://i1197.photobucket.com/albums/..._/DSC_4543.jpg New brake lines. http://i1197.photobucket.com/albums/...0/DSC_4753.jpg I had to get longer studs for my wheels..... http://i1197.photobucket.com/albums/..._/DSC_4550.jpg .....so I got these spendy one's from ARP. Thanks Andre (SavageNFS) for helping me get them cheaper. They are PN 100-7707. http://i1197.photobucket.com/albums/...0/DSC_4729.jpg The new studs and 2" nuts work much gooder! http://i1197.photobucket.com/albums/...0/DSC_4878.jpg Next up....new rear leaf springs. http://i1197.photobucket.com/albums/..._/DSC_4538.jpg |
When are you going to make some actual progress?
LOL...sorry buddy! Looks like a pro job! |
Great progress Gavin, nice clean work place, looks great so far....
Thx for the kind words |
Glad to see some updates on this. Looking good.
Very nice work Gavin :)
Wow... x2 on the color... x2 on the awesome...
Looks like its in excellent hands... subscribed. Love my dent but always intrigued by the bumps... could be the nickname :D |
That's one hell of a job you did on that rear end!
Wish I had myself a shop press and a lathe... Those two things are almost mandatory for doing DIY work. Looks great tho, keep those pics coming! |
