Now I know the standard is "Do your own work" but I'm not so good with engines. If I were to get a 460 and build it up, it would be done professionally at a shop or something. The other option is something like this:
http://www.summitracing.com/parts/hp...a/instructions Sure $7k doesn't come easy but as afar as I can tell it's a quality build. I don't know performance or cams or nothing like that so I *assume* it's fine. I checked Jasper Engines but of course, they don't offer a catalog. They pretty much force you to sign up with an email and all that garbage just for a price. |
I'd look for a rebuildable big block. Old Lincolns, F series trucks and even some old U Haul trucks have the 460's. I found a couple 460's in some old U Haul trucks. You can rebuild a big block for a lot less than $7500. Remember you'll have to get a truck oil pump pick up and oil pan (rear sump). I think Milodon and Moroso both make them. L&L is pretty expensive.
If you do the build yourself, use good parts and do a "close to stock" build.......I think you'll be pretty pleased. You're gonna love the instant throttle response and torque of a big block. Get a good 4 barrel, aluminum intake ( the stock cast intake is HEAVY!). A word of advice.......invest in the L&L motor mounts! They ARE worth it! I think there is other "heavy duty mounts" out there, but I can't remember the name of them. :-huh You can even use the crank mounted power steering pump (from early Lincolns) and I hear it works better than the later belt driven and they're real cheap to rebuild.......IF you can get them off the crank without destroying it! |
See the issue is, I won't end up rebuilding it. It will go to a shop to get done and since I don't know anything I would be like your average blonde shopping for spark plugs. If I tried to do anything I'd get halfway done disassembling it and lose intrest just like the 302 I've been working on for the last 4 years. Rods are pulled and lost, heads off and derusted, pan off. And it sits.
Buying one pre built is more expensive but then I don't get effed over by a shop trying to get me to buy stuff I don't need. Sent from my HTC One S using IB AutoGroup |
You haven't ridden in a 460 bronco.
Does it matter if I haven't? I having ridden with a stock 351m and 3.55 gears. I'll bet that alone is enough. Problem is I've got crap gears, a worn motor, and no money. Sure a stock or slightly modified 460 will have some 200-300 hp and tq, but like you said. Go big or go home. Soon my old girl will be a weekend warrior or a toy. I'll have a dd that gets better mileage and is more practical, the bronco will be driven when I feel like being badass :D.
For now nothing will happen, I just started a new job so untill the bacon starts cooking, I'll have to really pinch pennies. Today I will be asleep most of today and when I get up I plan to try some light tuning on the bronco. Reset the mix screws, check timing etc. Soon after I do the brakes, new plugs, wires, and fuel filter. It's got a miss I'm a little worried about.
IT DOES MATTER. Period. You missed out on something great. Something better since sliced bread.
You won't be a badass until you drop the monster 460 in it. It will tremble Washington state when you crank it up. It will make Mt. St. Helens erupt again. |
I installed spring perch and spring for tranny kickdown. Since I also have a 2" phenolic carb spacer I also had to fabricate an extension for the kickdown lever. I havent checked mpg yet since installing new carb, plugs and wires but I havent used my normal 3/8 tank this week to go 105 miles, so I am hoping the $$ I spent will translate into around 10 mpg. If it does it will pay for itself in about 7 months. Anything after that is icing on the cake.
:-drink |
ya i really like them 460's!
Originally Posted by ManfredVonRichtofen
(Post 13595838)
You won't be a badass until you drop the monster 460 in it. It will tremble Washington state when you crank it up. It will make Mt. St. Helens erupt again. Sent from my HTC One S using IB AutoGroup |
Originally Posted by GruesomeJeans
(Post 13594242)
CJE that looks pretty cool. Are you planning to paint the push bar black again?
I'd love a crate motor that's been bored out. No just a 460 but maybe something bigger. Ported polished, the whole shebang. I wouldn't mind a 400 since I like the dry heads and intake but I also wouldn't mind a 460. My one concern at the moment is if I did swap in a 460 did I waste $200+ on a set of hooker headers? Or will they swap onto a 460 too. Sent from my HTC One S using IB AutoGroup |
Sounds like a good plan.
Discovered last night that my EGR tube was cracked...now I know why I was getting an EGR code!
Ordered a replacement from PCI for half the price that everyone else wanted $42. Check them out here if you need one! |
You will see her mpg go up now since u fixed it.
I found me some dick cepek mud country (35x12.50x15) tires for $500. Guy wanted $650 but got him down. Maybe these will last until I can get some newer tires. Going to try to get them on today but I also need an alignment! Maybe they won't rub too bad with no lift |
(Post 13601724)
I found me some dick cepek mud country (35x12.50x15) tires for $500. Guy wanted $650 but got him down. Maybe these will last until I can get some newer tires. Going to try to get them on today but I also need an alignment! Maybe they won't rub too bad with no lift Be sure to post pics of the Bronco with new meats. |
