What did you do to the Bronco Today? - Ford Truck Enthusiasts Forums
Old 08-22-2012, 10:13 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
I searched all over but couldn't find a thread like this on the Bronco side. If there is one that I didn't find just have one of the mods delete this one please.
With all that said, post up here and let us know what you did to, or with, your Bronco today. Anything from completing an axle swap to starting it to move it over in the driveway. There are lots of build threads to keep up with so feel free to keep it a short update here as a reminder for the rest of us to check your build thread for the complete update.
Today I started cleaning off the firewall to weld some reinforcement plate on due to my hydraulic clutch conversion. No pics yet as the camera is acting up but I will post them.
Let the fun begin.
Old 08-23-2012, 08:17 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
I cleaned up the engine bay, getting ready to replace the header gasket. Had to order some nice copper gaskets, hopefully they last.
Old 08-23-2012, 08:30 AM
the truth's Avatar
the truth the truth is offline
the truth is starting off with a positive reputation.
Quote:
Haha. Have to have pics.
Old 08-23-2012, 10:34 PM
bigzirb's Avatar
I cleaned up the firewall to prep it to weld in some reinforcing metal. I was only cleaning around the holes and the perimeter where I will be welding so the rest is still covered to help prevent rust issues.
Tomorrow starts the welding.
Old 08-24-2012, 09:33 AM
Boss351Bronco88's Avatar
Boss351Bronco88 Boss351Bronco88 is offline
Boss351Bronco88 is gaining momentum as a positive member of FTE.Boss351Bronco88 is gaining momentum as a positive member of FTE.
I stare at it in the garage, waiting in anticipation for the motor. Pick it up the 31st. Dropping it in that weekend and coming out the garage tires blazing.
Old 08-24-2012, 10:53 AM
cje07's Avatar
cje07 cje07 is offline
cje07 is starting off with a positive reputation.
Too funny boss...guys its been along time since I have been on the site! My Bronco has been parked in the stall for the last 2 years. If any of you recall I did a full body resto complete with bedlining on the whole thing!
I had to park it because of other mechanical work that needed to be done...needless to say I run or ride my bike to work over the last 2 years...now, its time to bring it back out. Gotta do an oil change, new oil pan, TPS change, steering gear gasket...blah, blah. You'll see me more active in the coming months.
Anyway...I just stared at it and day dreamed... safari rack to come too!
Old 08-24-2012, 11:46 AM
bigzirb's Avatar
I started welding on the firewall, figured I would post a pic on the lunch break. I also need to let it cool before I continue tack welding it in place.
Keep up the work guys!
Old 08-24-2012, 01:16 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
I repaired my rear window motor by opening it up, cleaning out the crunched up bits of plastic, and replacing the bushings with 1/4" nuts. Works better than ever.
Old 08-24-2012, 02:37 PM
Southern Bronco's Avatar
Southern Bronco Southern Bronco is offline
Southern Bronco is gaining momentum as a positive member of FTE.Southern Bronco is gaining momentum as a positive member of FTE.
Replace my ignition coil w/ a MSD, cleaned the throttle body, and replaced the IAC valve. Also replaced a couple of missing screws in the D/S door panel
Old 08-25-2012, 12:29 AM
ford1977owner's Avatar
ford1977owner ford1977owner is offline
ford1977owner is gaining momentum as a positive member of FTE.ford1977owner is gaining momentum as a positive member of FTE.
today i got a wire wheel, got rid of the rust on my back rear, and leaf springs, paint them black along with some other things underneath, getting read to paint the frame, shackles, front springs all yellow
Old 08-25-2012, 09:52 PM
justgunner's Avatar
justgunner justgunner is offline
justgunner is starting off with a positive reputation.
installed a new stereo w/dvd,.and some speakers,.weird that,.there is a wire they want you to hook to your parking brake light, so you wont watch dvd's while driving,.,LOL I grounded it and it works just fine while driving, LOL (mobile ****),.but really i'm getting a dvd monitor for the back for camping and such,.it works good and for a 3.5" screen its really clear,.
Old 08-25-2012, 11:01 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Hello hello. Today, i did half of a hub rebuild on TGM. I had 2 broken studs so now i got all 5 new ones along with a brake rotor and bearings. Tomorrow will be the driver side. I would drop some pics but i just posted 27 of them here..
http://www.ford-trucks.com/forums/11...ct-tgm-13.html
It was my first time doing hubs. not as bad as i thought.
Old 08-26-2012, 10:03 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Abandoned, is it more noisy now?.
Well, I went to the window and watched the Bronco, she looks nice all cleaned up. It hasn't been that clean in months.
Old 08-26-2012, 12:09 PM
Quote:
Not at all, the nuts don't rotate, they're just internal bracing for the motor to gear. Nice cheap fix and stronger than original!
Old 08-26-2012, 12:49 PM
Encho's Avatar
I know, I have it on my truck, but I was told so and since I can't remember, I ask.
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-09-2017 01:38 AM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 125 04-23-2016 12:13 PM
bullnose bronco build thread 1985 Bronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-09-2014 01:01 PM
Big bronco general talk thread! im2tall33 1978 - 1996 Big Bronco 370 02-13-2013 02:07 PM
Blue Oval Dismantlers - Master Parts For Sale Thread - Updated Daily BlueOvalDismantlers Vendor Specials, Discounts, Product Announcements & Group Buys 11 08-08-2012 06:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
