It was probably a bit easier to find 8 lug ones. Finding 5x5.5 wheels is a bit difficult.
Originally Posted by Jarryd
(Post 13830812)
Good luck looking for some if that's your plan! |
I'm looking but come Saturday, the new tires will be mounted one way or the other.
Finally got a chance to knock out a project I have been DREADING:
Replacing the Bushings in my Pedal Assembly. Went to a friend's house at 4pm and started the teardown. Everything went as smooth as butter and not one hiccup. Pulled the assembly out and the bushing on the far right was TOAST. Literally was almost cut in half. Pulled the cross shaft that holds the bushings in place, out and found that the holes in both sides of the assembly "Box" was also toast. So my friend broke out the MIG welder and built the egg shaped holes back into actual circles. To get it how I wanted, he would grind everything down, stick the bushing in, mark where the dips were in the hole, and add metal. 6:30pm we were cleaning up. Total cost was $31.72 from LMC Truck for the Bushing Kit and the shipping. __________________________________________________ __________ Now that I have a pedal assembly that is correct, it has ZERO slop in it when shifting, taking off, etc. Also noted a BIG change in where the clutch engages/disengages from the floor up. Previously, it would engage about 2" from the floor; And now it's closer to 6" and only 2-3" from the main end of the pedal travel (Pedal pushing out to normal position) Definantly gonna take a while to get used to again; But at least it is working PERFECTLY now! :-jamming Next project will be Axle Pivot Bushings. I have the bushing kit, but no place to jack the truck up; Or a Ball Joint Press kit. But Michelle is definantly getting her groove back! |
Sounds good Wes, well done there...
Originally Posted by Bob Gervais
(Post 13824607)
If the buyer is aware of the 6.0 issues before buying, there's no need to shy away, as long as bulletproofing is accounted for in the purchase price. I've actually seen a few that have already had head studs and new gaskets installed still going pretty cheap.
From what I've read it's a hit or miss situation with the 6.0. Some owners have reported problems with low mileage, some have 300k miles without major issues. Roll of the dice, I guess.
Gerry, you have a 6.0, how has yours held up? Anything mechanical done to it? |
(Post 13831584)
(Post 13831584)
(Post 13831584)
QUOTE] Yeah, the 6.0 can be unpredictable. I too have heard of both kinda of cases. Some people say you have to work them hard, but I've seen them worked hard in fleet usage and still have major issues. Even issues that destroyed the block. I know of one that's on it's 3rd engine and the rest of the truck has 41x,xxx miles on it. Bob I don't think Gigger has had any problems with his 06 and he has had it since new but he has done quite a few mods to it and has low mileage. He may have had problems with it just I have never heard of any. Also Bob judging by how into it you are about possibly getting one you should check out the super duty or 6.0L part of the forum I bet they can give you hard evidence being they own them plus they are nice over in the super duty part (not sure in the 6.0L haven't been there but I wouldn't doubt they are). Trav |
well I dented the bumper and almost got ran over, think it may be a case of False park, as the truck was in full park with the ebreak set and she rolled into the corner of the house and took a bit of the garage door out, other then that not a lot...oh almost got ranover and killed by the truck...and shes starting to burn oil...
[QUOTE=Redneckfordf2502002;13832486]
Originally Posted by BigBlockF350
(Post 13832219)
Also Bob judging by how into it you are about possibly getting one you should check out the super duty or 6.0L part of the forum I bet they can give you hard evidence being they own them plus they are nice over in the super duty part (not sure in the 6.0L haven't been there but I wouldn't doubt they are). Trav I've read a lot in the 6.0 forum here too, and also on a couple of diesel sites, just to get information and opinions. At some point, I will take the plunge into a 6.0, when the right truck at the right price at the right time appears. :) |
One of my tires came in today. hopefully the rest come in tomorrow. I held one up to my old ones and it looks like they're about an inch taller than the old ones.maybe due to the worn out tread.
(Post 13830812)
I can relate... |
I've pretty well given up. I can't wait to get the new tires on though.
1 Attachment(s)
Then I must have lucked out when I found my wheels for $80 painted them and got the 33's for free lol
