Originally Posted by Puddy
(Post 13735691)
If they can ship to canada, I'm sold.
*Edit* Just realized its about $425 to ship a block ... |
Started to mount 3 switches in my dash
We got the fuel filter off today. Took a good 35-45 minutes to get it off.....after that, walk in the park to get new one on. Haven't driven it far enough to tell a difference, but anything should help. The mechanic doesn't believe it has ever been changed, if it was, it was probably on a 30-50K tune-up. I honestly didn't think it was that bad.....but at first, you couldn't even blow air through it. After finally letting it drain some gas out, you could barely get air through. Should help tremendously!
Lesson learned today: spend $6 and change on a filter and change it every 30-50K, rather than waiting till it hits 400K, lol |
Originally Posted by Sapphire Blue_95
(Post 13738439)
I finally got to installing the new brake shoes. Got the right side done and reassembled. Then I dropped the auto-adjusting lever and spring for the left side in the grass and couldn't find them. Good thing Advance Auto had the repair kits in stock.
This is turning into a saga. It started with needing new rear tires, and is ending up with me planning to rewrite both Chilton and Haynes. |
(Post 13734444)
Well had all of this stuff done today. Also cleaned the throttle body, can really tell a difference in throttle response. I also bought a fuel filter, but the mechanic couldn't get it off! With just over 184,000 miles, it's never been replaced. It is STUCK! We sprayed it with PB Blaster, hoping tomorrow it will get freed up.
One of many things to come. |
(Post 13735257)
Well place one wants $2800 and change just for the long block. Anything better out there? Guess there goes my supercharger money for the mustang.
This was on my shops 96 f350
https://scontent-a-sjc.xx.fbcdn.net/...79846306_n.jpg Both drums were stuck and the one on the driver side was split. The star adjuster for the shoes was also just rolling around in the drum and there were broken springs too. Had a charging issue on my 91 https://scontent-a-sjc.xx.fbcdn.net/...63814066_n.jpg Bought a replacement connector from napa. I am doing a 3g swap on the truck soon and am currently waiting for my parts but I needed the truck asap. |
That drum looks scary.
Cleaned out the bed to get ready for tailgating at the races this weekend
That drum looks sketchy dude
Took off the topper, so I could put a toolbox on instead
Originally Posted by Krisverde
(Post 13740627)
https://scontent-a-sjc.xx.fbcdn.net/...79846306_n.jpg I had chunks peeling off the open end of the drums, but at least they weren't split. Yet. |
New rear tires: check
New rear brake drums: check Painted brake drums: check New rear brake shoes: check New adjuster hardware, both sides: check Lug nuts torqued to spec: check Pulsating brake pedal fixed: check I'm almost afraid to put the new HO2S in. Will that become another saga requiring me to replace the exhaust valves, exhaust manifolds, Y pipe, and cat by the time I'm done? |
Put new air intake sensor in.. Maybe this will fix my surging idle and running rich
