Misc ford parts.
Misc ford parts.
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000, Hybrids
Item Condition: KY
Engine: Part suitable for gas truck, Part suitable for diesel truck
here is a list of most of them.
2 starters that came off a manual shift 302 (one of them is brand new only turned the egine over a couple times)
mech fuel pump also for a 302. It only pumped fuel a couple times when trying to get engine started.
new clutch pressure plate and throw out bearing from a 302. It was installed but never even had a pedal attached to it.
gas tank out of an 81 Bronco (33 gallon) with the small sender hole. This tank has no holes in it.
An accel points elimanator distibutor for a 302.
The grille and plastic rad support for a 92-96 Fseries truck.
9" rearend out of an 81 Bronco.
I also have a C6 4x4 tranny that will fit behind a 6.9 or 7.3 IDI diesel. This tranny was working when I removed it and put in a t18.
I am open to offers on all the gasser parts. The C6 however is firm at $400. These are not the easiest trannies to find anymore and I searched for a week to find this one when mine went out last winter. I paid $600 for it then.
