Running the red ELC coolant in the 6.4?
#31
#32
#34
#35
#36
#37
I just flushed mine, I filled and drained with distilled 3 times then changed the T-stats and flushed 2 more times with distilled and then added CAT ELC. I am pretty sure after my initial dump and refill with distilled I used a gallon of restore that I got at the Cummins dealer. Thats how I have read on other forums to do the flush and its been since july and all is good but I think I still have some air in my fuel cooler since you need to disconnect the lines to get to the T-stats. Its a good solid 6-8 hour job from start to finish
#38
#40
It's be great! Took a new job that gave me a company truck so mine is only driven on the weekends now. Gonna start on all the additional stuff I've been wanting to do. Starting with the EGR & Coolers.
Then I may do an Air Dog or FASS system.
How about yours? Have you made it to 36,000 miles yet? Still running a Bio?
#41
Yes, I have about 44,xxx on it now, still running great! Burning Bio when the weather allows, I just burnt the last of it in the tank for this year. I only put 6-7k a year on mine as I too have a company truck, got a new f-150 with the eco-boost last November . I really like it, plenty of power but the mileage is a bit lower than i expected. I have about 28k on it now and no issues yet.
#42
EGR & Coolers deleted. Took a little over 4 hours. Didn't flush or refill the coolant. Ran out of time. It's now a lot easier to get to the t-stats now so the flush will be easy. Engine bay looks a lot cleaner. EGR is completely clogged.
I think the instructions should say you should enlist the help of a contortionist to assist with some of those bolts.
#44
#45
Especially if you put in a new intake and get rid of the egr valve.
