ABS and brake light on
Both of the lights (yellow ABS and red "brake") stay on constantly while I'm driving. The only way I can get them to shut off is if I press on the brakes quite hard to come to a stop (they won't go away if you're in park and press down.)
I'm thinking this had something to do with a recent seafoam I did. At first I thought maybe I didn't secure the vac line tight enough to the brake booster but it's fine.
Also might note that my brakes feel no different.
This is what it was on a 92 Explorer I used to own. Both lights were lit on it too. The brakes worked fine, in fact we drove it for months this way after I checked the system out. The ground cable for the battery had one of those cheap replacement ends on it. A previous owner had put it on there and I was too lazy to replace it. About every 2-3 months I was having to replace that end due to corrosion. I got tired of it after a year and purchased a correct cable from Autozone. After I got it changed those lights went out and never came back on again. It might be worth a look to see if that is your problem.
Chris
Chris
Chris
Chris
