You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
how do you shut off the back up alarm when the tailgate is down or backing up a boat?? my 2008 had a button, I must be blind I cant see one on the 2011
As soon as the alarm starts an option pops up on the information center asking if you want to turn it off. Using the selector of the steering wheel, select off and then OK.
__________________
2011 F350 6.7 PSD Lariat CC SRW LWB 3.31 Build date 9/15/10
2003 F350 6.0 PSD Lariat CC DRW
1995 CK3500 454 CC DRW
1986 F250 460 SRW
I removed the back up alarm in a buddies F150 a couple of years ago and I replaced his drivers side back up light bulb. The bulb had a alarm noise maker built right into the bulb. Replaced the bulb with a standard bulb and the alarm went away. I don't know if its the same thing today though.
__________________ 2011 F250 Super Duty 4x4 XLT Crew Cab 6.7 Scorpion PSD
Firestone Air Bags--Bilstein 5100's--Epic's Door Seal Mod--GT Exact Fit Camo Seat Covers--Husky Molded Mud Flaps
Silverstar Ultra lights--Steelcraft Bull Bar--AMI Chrome Locking Fuel Door
1990 "Barstow to Vegas" built Yamaha Banshee
Professional Outdoorsman with Team Browning
Sounds like you might be talking about the exterior chime backup alert... you know... the beep, beep, beep thing....I think bobby was asking about the interior backup alarm.... the ding, ding, ding thing.
__________________
1986 F250 460 SRW
I thought that when a trailer is plugged in the chime is supposed to be shut off? I guess the new trucks don't just have the simple button next to the 4x4 switch?
Mine even beeps at me if I leave my hitch in the receiver. It's a pretty substantial hitch though. I finally got tired of canceling it every time I backed up and removed the hitch for the time being.
Yes, it shuts off when a trailer is connected. The on/off screen also pops up whenever you put it into reverse.
Wow, the only thing that happens when I back up is the rear view mirror camera picture comes on and I start moving in reverse. No ding-ding.
Mine does not alarm when there is a 7 pin trailer plug in the socket, maybe the 4 pin is not "smart" enough to signal the alarm to be off?
I wonder if a fake plug could be made to leave in the socket so that the backup alarm is always off? But then, the truck would think that there is a trailer there, activate the anti-sway system, run different calculations on the oil life, who knows how many other things would be thrown off.
__________________
2011 F250 6.7 4X4 Lariat Ultimate FX4 3.55 ELock
Polk Audio component speakers, AFE Stage 7 intake
Sho Me Strobes, Shocker XL Horns, BakFlipG2
2 Kicker 10" subs, Rockford Fosgate amp
Ride-Rite air bags, VIAIR #10007 onboard air, AFE DPF back exhaust, power slot rotors/EBC pads, Nitto Trail Grapplers M/T 295/55 R20! Transfer-Flow 50 gal tank
You need the Reverse Vehicle Aid Sensor. Order code 76R. Standard on Lariat. Optional on XLT.
If you have it, it will start to beep after you place the truck in reverse... but only when you approach within so many feet of an obstacle.
As you get closer to the object the beep will quicken. When it becomes a steady beep you are almost up against the obstacle.
I had this on my 03' dually and became so dependent on it that when I ordered my 11' I made sure that I had it. I actually trust it/use it... more than the reverse camera.
__________________
1986 F250 460 SRW
My reverse alarm was driving me crazy. (the beep, beep, beep in the rear of the truck when backing up). I disconnected it. It is located on the frame behind the rear bumper on the passenger side. I just unplugged it and now I don't have to listen to it any more.
I miss the big button on the dash for the back up sensor that was on my 2008 F250. I could find it anytime, it never moved, and I could press it without looking and turn it off quickly.
It seems that when I back up with my tailgate down on the 2011 to hook up the 5th wheel, the steering wheel is always upside down when the alarm goes off and I have to locate the arrow buttons (that are now upside down and press down (or up!) and then OK. The message is displayed in the LCD screen and the only way to turn it off is to find the arrow keys and press ok. It kinda gets on my nerves how they programmed it like that. Ford - if you're listening, put the button back on the dash so its easy to find and its never upside down!!
__________________
2012 Ford F150 Platinum 4x4 Super Crew 3.5 EcoBoost, BakFlip F1 bed cover
2011 Ford F350 SD 4x4 SB Lariat Super Crew 6.7 11.5k lb GVWR
2008 Ford F250 SD 4x4 SB Lariat Super Crew 6.4 PSD, Timbren SES, 16k Husky slider, Michelin LTX A/T 2
2005 Ford F150 Lariat 4x4 Super Crew 5.4
1987 Ford F150 XL 4x2 Flare Side
So you actually have to answer a question to shut it off with the LCD screen?
I have the simple XLT screen and I only have to press the down button (reset) to shut it up. No answering any questions, [on] or [off].
The reset button could be up depending on the wheel position as you said but still easy to do.
