1966 F250 window seals
Welcome to FTE, Bill has mentioned the article in D.C catalog; the article is on page 125 in the online, or paper back catalog. IMO, their weatherstrip, window gaskets, vent seal, etc. are made to fit, not much, if any, trimming required, may find cost more but kits are very good qaulity. If decide to go the D.C. route believe the catalog is still free; if so, suggest adding to the cart.
Hey Brad,
Welcome to FTE...if you go to Dennis Carpenters website, download the pdf catalog and you'll find it on page 95 of the pdf. The directions are a bit vague....but you can figure it from there.My advice, given to me by a friend, gangstakr, on this site, is go to a wrecking yard and practice removing old anti-rattles felt kits. After one or two, it is pretty intuitive.If you're changing your A.R's, be sure to re-do the vent window seals too, that way you're doing the entire thing and it'll be good as new. A far as the window seals go, just be sure you get the right one for your style of front window...ie, whether or not it has the custom cab trim. If it has the trim, it's a bit tricky, just be patient. Rear window is a snap....use the string method.A.R's + vent seals (+ window bar) will run you around $270.
