My truck needs to pick a side of the fence
Sometimes it does, sometimes not. Sometimes its white smoke, thats usually if it doesn't crank for very long maybe 2 or so seconds. If it cranks for 4 or 5 seconds, then ya, usually its accompanied by blue smoke for a few seconds. Your saying even after replacing IPR o-rings, it still does that?
At least on my truck it still does that. I think the blue smoke is from oil leaking around the Injector O-rings into the either the fuel, or straight into the combustion chamber. Either way, I changed the IPR o-rings to try and correct a lopey idle and vibration when the truck is warm. It did not fix that problem. I've had the pcm reflashed too. Also I have the new Black CPS. That made it run alot better, but it still isn't right. I also replaced the Glowplugs last summer, along with the UVCH's, VC gaskets, and put new pigtails on the two 5-wire plugs on the passenger side. They were all melted. The truck started awesome last winter, but I can tell its already starting harder this year.
The blue smoke on cold start-up started to happen early last spring and has steadily worsened. The only thing I know to try anymore is new injector o-ring and possibly and injector rebuild.
#29
The low voltage when cranking does also concern me. Is there a way to do a load test myself without having to go down to the auto parts store? I dont have any other transportation and its tough to ride a bike with a battery in one hand.
#30
