Spring Swap ProComp 22210/22415 w/ PICS
#31
#32
#34
#36
hi, Question for all who have done this set up. I'm looking to do the same. I have the Rancho 9000's and ordering the Procomp Springs this week. My question is what U-Bolts? I see some people had them made others bought other brands. Do the front and rear need be be changed or are any long enough. I plan to remove the factory rear blocks so the truck will sit level. I' m just trying to have all the parts ready. Thanks.
#37
Parts list
I've had the 2002 excursion fro 8 years before I decided to put this lift on it. I put the lift on last weekend and it went smoothly. I didn't want to have u-bolts made b/c I wanted all the parts in the garage so I didn't have to stop. Here is my parts list.
Parts for lift:
Front U-bolts - Only need two w/ nuts for the driver's side: Pro Comp 13-90510A, passenger side u-bolts are long enough
Rear U-bolts w/ nuts: Tuff Country U-Bolts 17752
Drop pitman arm: 70201 Tuff Country - Pitman Arm
Trackbar bracket: Tuff Country 20904
Front Shocks: Rancho RS999264 RS9000XL Series Shock
Rear Shocks: Rancho RS999275 RS9000XL Series Shock
Rear Springs: Pro Comp 22415 5" Rear Leaf Spring, remove the rear OEM 2" blocks
Front Springs: Pro Comp 22210 Black Powdercoated Leaf Spring
Front and rear wheel well measurement are the same at 42" w/ 285/75r16 tires. But these tires only measure 31" when on the car. Even though both ends are at 42" the car is not level. I put my 4' level on the roof and the back sit about 1/2-3/4" lower than the front.
I am planning on putting on 315/75 and still fitting in the garage which is 7'.
I ran the truck for a week before putting on the drop pitman arm and track bar bracket. The drop pitman arm is a good idea but I do not like the track bar drop bracket. It seems like it over compensates and actually pushes the axle 1/2" too far towards the passenger side. I'm still brainstorming on how to fix this. I'd like to put the stock bracket back on but I think you need a drop bracket if you run a drop pitman arm.
Next up is the 2007 front grill, lights, tires, and maybe wheels. My tire store said they'd put 315's on the stock 16x7 rim.
Parts for lift:
#38
#39
I'll look into the adjustable track bar but I think I'll try to fix the mount first. The ride is much better than stock.
#42
No, but I only had it for a week w/ the stock pitman arm. But I noticed the steering was a little stiffer after the lift w/ the stock pitman arm. The drop pitman arm made the steering easy again like stock.
1970XL351W
1999 to 2016 Super Duty
04-11-2014 10:45 AM
mdula
22
04-02-2013 04:37 AM
