Clutch and Slave recomedations wanted
I am looking for recommendations and feedback for a new clutch. I was planning on LUK clutch, PP and Slave but they are a little pricey. is Perfection(advanced auto) any good? all feed back wanted as well as best source for parts.......thanks in advance...
Ive got one fro autozone, lifetime warrenty and they have replaced 1 already no qustions. They also have the same warrenty on the slave cyl. Dont know about the master, but plan on R&R all if you do pull the trans for the clutch. This is the best recommendation I can give as I have had mine out several times, did master slave failed, did slave master failed!
Also pack the TO bearing with a good grease, as well as the pilot bearing when reassembling.
Only reason I exchanged mine was that my 5th/OD went out and I had the trans out. talked to the guy at AZ and he said just to bring it in and get a new one. Was nothing wrong with it. Now have 100+K on the one I put in no problems. I do thiink my master cyl is getting weak as it starting to get hard to shift again but the truck has 300+K on it so go figure.
