1995 7.5L V8 misfires while towing load
Old 09-24-2010, 06:42 PM
mdl95003's Avatar
mdl95003
mdl95003 is offline
EGR solenoid has been replaced by dealer, vacuum leak corrected at EGR. Vaccuum tests of EGR valve show valve o.k. No other codes generated after above repairs/systems check. 50 miles into the trip today, problem recurs, only when engine hot/under load. Coil replaced, wires and plugs replaced. Fuel pump problem ruled out by switching between tanks to verify pump operation--unless both pumps are simultaneously bad, can't imagine that it is a fuel problem. Truck engine totally rebuilt at 140K miles, as well as transmission replaced at that time, both done by reputable independent auto repair shop. Now has 150K miles, and this problem has just surfaced within last few days only 300 miles into a 1100 mile trip with 5th wheel. Any ideas/suggestions/tips?
Old 09-25-2010, 11:39 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
You're in the wrong forum for the 7.5 engine.
Old 09-27-2010, 09:34 PM
TwoCrews's Avatar
TwoCrews
TwoCrews is offline
Make sure #7 and # 8 spark plug wires do not run next to each other. If they are routed next to each other voltage will induce in the other wire at the wrong time and will cause a miss.
Okie Dax
15
11-05-2021 07:39 PM
rgnprof
04-03-2017 12:14 PM
coolfeet
06-27-2016 04:05 PM
coolfeet
03-29-2016 05:56 PM
RGrimes
1997 - 2003 F150
02-07-2006 12:36 PM
Quick Reply: 1995 7.5L V8 misfires while towing load
